29251 Discussions
ifort v:12.0.4 Bug: OpenMP segmentation fault
Kamil_Kie
When I compile below code by "ifort -openmp bug.f90" and run I get "Segmentation fault" :
[fortran]program bug
  implicit none
  integer :: n
  parameter (n=1024)
  real :: A(n,n),B(n,n),C1(n,n),C2(n,n),C3(n,n)
  print *,"hello"
  A=1
  B=2
  C3=3
  if(.not. all(C1.eq.C2)) print *,"error C1!=C2"
  if(.not. all(C1.eq.C3)) print *,"error C1!=C3"
end program[/fortran]
For n=512, or without "-openmp" option, everything is fine. How to fix it?
jimdempseyatthecove
Either use heap arrays or
real, save::A(n,n),B(n,n),C1(n,n),C2(n,n),C3(n,n)
Jim Dempsey
jimdempseyatthecove
Jim Dempsey
Kamil_Kie
ok thanks.
