Problems with 18.1 and ALIAS attribute
Wolf_W_
Dear Fortran Forum,
i got a problem with the ifort 18 Update 1 Compiler. It seems the way the alias attribute is handled in submodules has changed. I can't get my code to compile with the alias attribute. I need it, to keep downward compatibility of the dll. Is this new behavior intended or a bug?
Greetings
Wolf
module M_MOD
  implicit none
  type T_TYPE
    contains
!    procedure, nopass :: foo ! This works without ALIAS
    procedure, nopass :: foo_renamed=>foo ! This works in none of my tests with 18.1
  end type
interface
  module subroutine foo()
!    !DEC$ ATTRIBUTES ALIAS:"foo" :: foo
    !DEC$ ATTRIBUTES DLLEXPORT :: foo
  end subroutine
end interface
end module
submodule (M_MOD) S_MOD
  implicit none
contains
    ! IFORT 16 to 18.0 give "error #7286: This symbol has multiply declared DEC$ ATTRIBUTES ALIAS attribute.   [FOO]"
!    !DEC$ ATTRIBUTES ALIAS:"foo" :: foo ! Until 18.1 it worked without this line
  end subroutine
end submodule
module M_USING_M_MOD
  use M_MOD
  implicit none
contains
  subroutine bar()
    type(T_TYPE) :: T_TYPE_INSTANCE
    ! IFORT 18.1 gives Link error: "error LNK2019: unresolved external symbol "M_MOD_mp_FOO" in function "M_USING_M_MOD_mp_BAR""
!    call T_TYPE_INSTANCE%foo()
    ! IFORT 18.1 gives Link error: "error LNK2019: unresolved external symbol "M_MOD_mp_FOO_RENAMED" in function "M_USING_M_MOD_mp_BAR""
    call T_TYPE_INSTANCE%foo_renamed()
  end subroutine
end module
Lorri_M_Intel
I'm sorry, I can't understand what you want to happen.
What I think you want, is for submodule routine named "foo" to have the external name "foo" (rather than the fully qualified module name).
What I can't easily work out, is which commented out code paths are good, which are problematic.
We did fix an issue with the  multiple ALIAS declarations, so yes, there have been changes in this area.
Can you post a version that worked in 18.0 but does not work in 18.1?  Maybe that would be clearer for me.
            thanks --
                                          --Lorri
Wolf_W_
I'm sorry, that i couldn't make things clear...
Yes i want "foo" to have the external name foo - i can work around this problem in most of my code, but i think this is a compiler bug. The ALIAS seems to be broken, when used with type bound procedures in submodules.
I just realized, that it fails without the renaming, too.
!This works in <=18.0
module M_MOD
  implicit none
  type T_TYPE
    contains
  end type
interface
  end subroutine
end interface
end module
  implicit none
contains
  end subroutine
end submodule
  use M_MOD
  implicit none
contains
  subroutine bar()
  end subroutine
end module
module M_MOD
  implicit none
  type T_TYPE
    contains
  end type
interface
  end subroutine
end interface
end module
  implicit none
contains
  end subroutine
end submodule
  use M_MOD
  implicit none
contains
  subroutine bar()
!    call foo() ! But it works, when not calling the type bound procedure
  end subroutine
end module
Greetings
Wolf
andrew_4619
As a matter of interest does bind(c, name='foo') work as that is surely better than using the not standard "alias"?
Steve_Lionel
The difference with BIND(C,NAME=) is that it behaves as if you had added DECORATE to the ALIAS attribute, so with 32-bit you get a leading underscore.
