29381 Discussions
Problems with Intel Fortran licence in Mac OS X
cresplum7
I got a free licence for students two days ago, and I downloaded the 11.1 version of the Intel Fortran compiler for Mac OS X.
I already have the GNU fortran version (gfortran).
I recieved an email after registering on-line with an attatchment of a licence and the serial-number to complete the installation of the compiler.
Once I installed it, I tried to compile with the command 'ifort', but I got the next message:
Error: A license for FCompM could not be obtained
Your license is not current enough to allow you to use this
newer version of our software. Usually this occurs because
your support services license expired before we created this
version. You will need to purchase a new license.
License file(s) used were (in this order):
1. Trusted Storage
2. /usr/bin/ifort-11.1-base/Licenses
3. /Users/cristian/intel/licenses
4. /opt/intel/licenses
5. /Users/Shared/Library/Application Support/Intel/Licenses/NCOM_A___XXXX-XXXXXXXX.lic
6. /Users/Shared/Library/Application Support/Intel/Licenses/m_XXXXXXXX.lic
7. /Users/Shared/Library/Application Support/Intel/Licenses/m_XXXXXXXX.lic
8. /usr/bin/ifort-11.1-base/bin/ia32/*.lic
Please visit http://www.intel.com/software/products to obtain license renewal information.
ifort: error #10052: could not checkout FLEXlm license
Then, I tried to copy the licence that I got in the email in the path that is specified in the error message (.5), but I got the same error.
What should I do to fix the problem?
Gergana_S_Intel
Moving this to the appropriate forum.
~Gergana
Cristian,
I looked up your license info and it looks ok. I suggest deleting all the other .lic files from that directory other than the one you saved there, and see if that helps. Let me know.
Andres_M_Intel4
Also, you may want to check your ~/.flexlmrc file.
It should contain a variabledefinition pointing toyourlicenses directory.
Hope it helps,
-- Andres
cresplum7
Cristian,
It didn't work.
I remember that I got an evaluation licence last summer for one month for the version 46 of the 11.1 build, and I didn't renew it. Now I've got the version number 80. I couldn't run the uninstall script for the 46 version (once I had the 80 version installed) so I simply deleted it, and that's what I still had the old licence in the next path:
Now there's just the new licence I got in that path, and the error message that appears when I run the compiler is slightly different:
Error: A license for FCompM is not available now (-15,570,36).
A connection to the license server could not be made. You should
make sure that your license daemon process is running: both an
lmgrd.intel process and an INTEL process should be running
if your license limits you to a specified number of licenses in use
at a time. Also, check to see if the wrong port@host or the wrong
license file is being used, or if the port or hostname in the license
file has changed.
1. Trusted Storage
6. /usr/bin/ifort-11.1-base/bin/ia32/*.lic
Please visit http://support.intel.com/support/performancetools/support.htm if you require technical assistance.
cresplum7
Hope it helps,
-- Andres
Can't find the~/.flexlmrc file. Where is it supposed to be?
cresplum7
I finally solve it installing theIntel License Managerfor FLEXlm* for Mac OS X.
Thanks for the support,
Cristian
Glad to hear it. It seems the license file you have left is a floating license.
