29255 Discussions
Problems with RESHAPE() intrinsic's ORDER parameter?
Deleted_U_Intel
I'm having trouble with the ORDER parameter in the RESHAPE() intrinsic. If I don't use it, reshape() works just fine. However, if I use order, the array gets gibberish. With this program:
program test
implicit none
real, dimension(1:3, 1:3) :: matr
integer :: i
matr = reshape((/ (i, i=0,8) /), (/ 3, 3 /))
do i = lbound(matr, 1), ubound(matr, 1)
print *, matr(i,:)
end do
print *
matr = reshape((/ (i, i=1,9) /), (/ 3, 3 /), order=(/ 2, 1 /))
print *, matr(i,:)
end do
end program test
I get the following output:
0.0000000E+00 3.000000 6.000000
1.000000 4.000000 7.000000
2.000000 5.000000 8.000000
0.0000000E+00 0.0000000E+00 0.0000000E+00
0.0000000E+00 -1.1987086E+09 -1.1987087E+09
1.0953484E+09 1.0934118E+09 -1.1987085E+09
In the case where order wasn't used, the output was correct. But when I try to correct for Fortran's column-major format with the order parameter, the array is filled with garbage. Anyone know what I'm doing wrong, or is this a bug in the intrinsic's implementation?
What compiler version are you using? It works ok for me in the current 8.0.047.
You need to register with Premier Support using the serial number included with the compiler (sent by e-mail if you got it online). You can then log in to Premier Support and download the latest compiler your license will allow. If you got a non-commercial (free) license, it will be as of the date the license was issued. If an eval, you have 30 days of free support, and if you have a full support license, you geta year of support and updates.
