Problems with Static Library
cesarpradosboda
I want to make a small program that uses a static library made in FORTRAN&C, to see how the calls work from Fortran to functions made in C when I want work whit Build Environment for IA-32 applications, the source of the program it's described next, if I use the Fortran command prompt, I am able to do it, but if I want do it from Microsoft IDE to develop, I obtain the next error:
Console1 error LNK2019: unresolved external symbol _WRITE_HELLO referenced in function _WRITE_SM()
The first step that I have make is a Project where I've made the library. In this work area there are two projects, one for the fortran files and and another one for the C files. I have configured of following form the PROPERTY PAGES:
FORTRAN/EXTERNAL PROCEDURES:
Calling COnvention-->Default
FORTRAN/LIBRARIES
Disable Default Library Search Rules--> No
The second step to do is the link the lib to the main program.
I've did "Add existing item-->prog.lib"
FORTRAN/LIBRARIES:
Result-->error LNK2019
If I change the next property:
LINK/INPUT:
Additional Dependecies-->prog.lib
Result-->
Console1 Fatal error cannot open "libra.lib"
Console1 error: problem during multi-file optimization compilation (code 1)
what is it wrong in the Properties?
Code:
LIBRARY
Code:Lib_c_64.h
#include
#include
#include
#include
#include
int write_hello();
Prog_c_64.c
#include "Lib_c_64.h"
int write_hello()
printf("Ciaooooooo");
return 0;
 Prog.f90
SUBROUTINE WRITE_SM()
INTERFACE
INTEGER FUNCTION WRITE_HELLO()
!DEC$ ALIAS:'_write_hello'::write_hello
END FUNCTION
END INTERFACE
INTEGER IO
IO = write_hello()
RETURN
END SUBROUTINE WRITE_SM
Thanks in advance
Cesar
