29648 Discussions
Problems with interface and function
aryangor
This is part of the module with the interface in it:
[fortran]
           ! Cubpack User Interface !
Module CUI
USE Precision_Model
USE internal_types
Implicit NONE
PRIVATE
PUBLIC :: CUBATR, CUBPACK_INFO
PRIVATE :: CUBATR_X, CUBATR_1, CUBATR_CLEAR ! ! Module variables ! INTEGER, SAVE, PRIVATE :: PreJob=0 INTEGER, PRIVATE :: BOTTIH,BOTTRH INTEGER, DIMENSION(:), PRIVATE, ALLOCATABLE :: IWork REAL(kind=stnd), DIMENSION(:), PRIVATE, ALLOCATABLE :: RWork TYPE(EPSALG_MEM), PRIVATE :: M INTERFACE CUBATR MODULE PROCEDURE CUBATR_X, CUBATR_1, CUBATR_CLEAR END INTERFACE CONTAINS SUBROUTINE CUBATR_X & (DIMENS,NumFun,Integrand,NumRgn,Vertices,RgType,Value,AbsErr, & ! and optional parameters IFAIL,Neval,EpsAbs,EpsRel,Restart,MinPts,MaxPts,Key,Job,Tune) !----------------------------------------------------------------------- ! Input parameters ! ---------------- ! ! DIMENS Integer. ! The dimension of the region of integration. ! ! NumFun Integer. ! Number of components of the integrand. ! ! Integrand ! Externally declared function for computing all components ! of the integrand at the given evaluation point. ! It must have input parameter X: ! X(1) The x-coordinate of the evaluation point. ! X(2) The y-coordinate of the evaluation point. ! ... ! X(DIMENS) The z-coordinate of the evaluation point. ! and NumFun, the number of components of the integrand. ! It must be compatible with the following interface: ! INTERFACE ! FUNCTION Integrand(NUMFUN,X) RESULT(Value) ! USE Precision_Model ! INTEGER, INTENT(IN) :: NUMFUN ! REAL(kind=stnd), DIMENSION(:), INTENT(IN) :: X ! REAL(kind=stnd), DIMENSION(NUMFUN) :: Value ! END FUNCTION Integrand ! END INTERFACE ! ! NumRgn Integer. ! The number of given regions. ! ! Vertices ! Real array of dimension (DIMENS,DIMENS+1,NumRgn). ! Vertices(1:DIMENS,K,L) are the x, y, ... coordinates ! respectively of vertex K of region L, where ! K = 1,...,DIMENS+1 and L = 1,...,NumRgn. ! ! RgType Integer array of dimension (NumRgn). ! RgType(L) describes the type of region L. ! ! Value Real array of dimension NumFun. ! Approximations to all components of the integral if ! the procedure is restarted. ! ! AbsErr Real array of dimension NumFun. ! Estimates of absolute errors if the procedure is restarted. ! ! IFAIL Optional integer argument. ! This follows the NAG convention: ! IFAIL = 1 : soft silent error ! Control returned to calling program. ! IFAIL = -1: soft noisy error ! Error message is printed. ! Control returned to calling program. ! IFAIL = 0 : hard noisy error ! Error message is printed and program is stopped. ! Default IFAIL = -1. ! ! EpsAbs Optional real argument. ! Requested absolute error. ! Default EpsAbs = 0. ! ! EpsRel Optional real argument. ! Requested relative error. ! Default EpsRel = sqrt(machine precision). ! ! Restart Optional boolean argument. ! If Restart = FALSE, this is the first attempt to compute ! the integral. ! If Restart = TRUE, then we restart a previous attempt. ! In this case the only parameters for CUBATR that may ! be changed (with respect to the previous call of CUBATR) ! are MinPts, MaxPts, EpsAbs, EpsRel, Key and Restart. ! Default Restart = FALSE. ! ! MinPts Optional integer argument. ! The minimum allowed number of integrand evaluations. ! Default MinPts = 0. ! ! MaxPts Optional integer argument. ! The maximum allowed number of integrand evaluations. ! Default MaxPts = enough to do 500 subdivisions. ! ! Key Optional integer argument. ! Can be used by Rule_General to choose between several ! local integration rules. ! Default Key = 2 if Dimension=1 and extrapolation is used ! (This corresponds to QAGS) ! Default Key = 0 otherwise ! ! Job Optional integer argument. ! If |Job| = 0, then nothing will be done except freeing all ! allocated memory. ! This is usefull after a call of CUBATR if no ! Restart will be done later and memory usage ! might become an issue later. ! Equivalently, one can call CUBATR() ! without any arguments. ! = 1, the global adaptive algorithm is called ! = 2, extrapolation using the epsilon algorithm is used. ! = 11, a region will be divided in 2**DIMENS subregions ! and the global adaptive algorithm is called. ! In combination with Key=0, this resembles DUCTRI and DCUTET. ! = 12, a region will be divided in 2 subregions ! and the global adaptive algorithm is called. ! In combination with Key=3 or 4, this resembles DCUHRE. ! If Job < 0, then an overview of the Region Collection is dumped. ! This will create the files tmp_integerstore and tmp_realstore. ! Default Job = 1. ! ! Tune Optional real argument. ! Can be used by Global_Adapt or the local error estimators ! to influence the reliability. 0 <= Tune <= 1. ! Tune = 1 is the most reliable available. ! Default Tune = 1. ! Note that this is an experimental and controversial parameter. ! In this version, only Tune = 1 is supported for all regions. ! ! Output parameters ! ----------------- ! ! Value Real array of dimension NumFun. ! Approximations to all components of the integral ! ! AbsErr Real array of dimension NumFun. ! Estimates of absolute errors. ! ! NEval Optional Integer. ! Number of integrand evaluations used by CUBATR for this call. ! ! IFAIL Optional Integer. ! IFAIL = 0 for normal exit. ! ! AbsErr(K) <= EpsAbs or ! AbsErr(K) <= ABS(Value(K))*EpsRel with MaxPts or less ! function evaluations for all values of K, ! 1 <= K <= NumFun . ! ! IFAIL = 1 if MaxPts was too small to obtain the required ! accuracy. In this case Global_Adapt returns values of ! Value with estimated absolute errors AbsErr. ! ! IFAIL > 1 in more serious case of trouble. !----------------------------------------------------------------------- ! MODULES USED USE Check_Input USE Error_Handling USE DS_ROUTINES, ONLY: DSCOPY, DSINIT, DSUSED, DSSTAT, DSSUM, DSPINT USE CubatureRule_General, ONLY: Rule_Cost USE Global_Adaptive_Algorithm !***END PROLOGUE CUBATR !----------------------------------------------------------------------- ! ! Global variables ! INTERFACE FUNCTION Integrand(NUMFUN,X) RESULT(Value) USE Precision_Model INTEGER, INTENT(IN) :: NUMFUN REAL(kind=stnd), DIMENSION(:), INTENT(IN) :: X REAL(kind=stnd), DIMENSION(NUMFUN) :: Value END FUNCTION Integrand END INTERFACE INTEGER, INTENT(IN) :: DIMENS,NumFun,NumRgn INTEGER, DIMENSION(:), INTENT(IN) :: RgType LOGICAL, INTENT(IN), OPTIONAL :: Restart INTEGER, INTENT(OUT), OPTIONAL :: NEval INTEGER, INTENT(IN), OPTIONAL :: Job,Key,MaxPts,MinPts INTEGER, INTENT(IN OUT), OPTIONAL :: IFAIL REAL(kind=stnd), INTENT(IN), OPTIONAL :: Tune,EpsAbs,EpsRel REAL(kind=stnd), INTENT(IN), DIMENSION(:,:,:) :: Vertices REAL(kind=stnd), INTENT(IN OUT), DIMENSION(:) :: AbsErr, Value ! ! Named constants ! INTEGER, PARAMETER :: NRINFO=1, NIINFO=5 ! ! Local variables ! INTEGER :: BLOCK,i,Inform,Leval,LJob,LMaxPts,LMinPts,MinCost, & NRVERT,NrSub,NRVACA,MAXRGN,RULCLS,STATUS,Tmp LOGICAL :: EpsAlg,LRestart REAL(kind=stnd) :: LEpsAbs, LEpsRel REAL(kind=stnd), DIMENSION(:), ALLOCATABLE :: TmpRWork INTEGER, DIMENSION(:), ALLOCATABLE :: TmpIWork TYPE(INTEGRATOR_INFO) :: CINFO TYPE(USER_INFO) :: UINFO !----------------------------------------------------------------------- ! ! Check array sizes ! Array size mismatch results in hard error. Inform = 0 IF (size(rgtype) < numrgn) THEN write(unit=*,fmt=*) "Error: size(rgtype) < numrgn" Inform = Inform + 1 END IF IF (size(abserr) < numfun) THEN write(unit=*,fmt=*) "Error: size(abserr) < numfun" Inform = Inform + 1 END IF IF (size(Value) < numfun) THEN write(unit=*,fmt=*) "Error: size(Value) < numfun" Inform = Inform + 1 END IF IF ((size(vertices,1) /= dimens) .or. (size(vertices,2) /= dimens+1) & .or. (size(vertices,3) < numrgn)) THEN Inform = Inform + 1 write(unit=*,fmt=*)"Error: size(vertices) /= (/dimens,dimens+1,numrgn/)" END IF IF (Inform /= 0) THEN WRITE(unit=*,fmt=*) "Array size mismatch results in hard error." STOP ! "Array size mismatch results in hard error." END IF !----------------------------------------------------------------------- IF (PRESENT(NEval)) THEN NEval = 0 END IF !----------------------------------------------------------------------- IF (PRESENT(Job)) THEN LJob = Job IF (Job == 0) THEN CALL CUBATR_CLEAR() RETURN END IF ELSE LJob = 1 END IF !----------------------------------------------------------------------- ! ! Set optional arguments ! IF ( PRESENT(Restart)) THEN LRestart = Restart ELSE LRestart = .FALSE. END IF IF ( PRESENT(Key)) THEN CINFO%Key = Key ELSE IF ((ABS(LJob) == 2) .AND. (DIMENS == 1)) THEN CINFO%Key = 2 ! simulate QAGS ELSE CINFO%Key = 0 END IF END IF !----------------------------------------------------------------------- ! ! Check input parameters ! IF ( .NOT. LRestart) THEN CALL CHECK(DIMENS,NumFun,NumRgn,RgType,Inform, & LJob,IFAIL,EpsAbs,EpsRel,MinPts,MaxPts,Tune) ELSE IF ( ALLOCATED(IWork) ) THEN CALL CHECK(DIMENS,NumFun,BOTTRH,BOTTIH,IWork, & Inform,LJob,IFAIL,EpsAbs,EpsRel,MinPts,MaxPts,Tune) ELSE Inform = 4096 ! There is nothing to restart from END IF IF (Inform /= 0) THEN CALL Handle_Error(Inform,IFAIL) RETURN END IF !----------------------------------------------------------------------- RULCLS = Rule_Cost( DIMENS, RgType(1), CINFO%Key ) MinCost = RULCLS DO i = 2,NumRgn Tmp = Rule_Cost( DIMENS, RgType(i), CINFO%Key) RULCLS = max(RULCLS,Tmp) MinCost = MinCost + Tmp END DO !----------------------------------------------------------------------- ! ! Set optional arguments ! IF ( PRESENT(MinPts)) THEN LMinPts = MinPts ELSE LMinPts = 0 END IF IF ( PRESENT(MaxPts)) THEN LMaxPts = MaxPts ELSE LMaxPts = 500*RULCLS END IF IF ( PRESENT(Tune)) THEN CINFO%Tune = Tune ELSE CINFO%Tune = 1 END IF IF ( PRESENT(EpsAbs)) THEN LEpsAbs = EpsAbs ELSE LEpsAbs = 0 END IF IF ( PRESENT(EpsRel)) THEN LEpsRel = EpsRel ELSE LEpsRel = SQRT(EPSILON(LEpsRel)) END IF !----------------------------------------------------------------------- ! ! Set other parameters of the Global Adaptive algorithm ! ! ! NrSub is an upper limit for the number of subregions after subdivision. ! This influence memory managment, so don't exagerate here. IF (DIMENS <= 3) THEN NrSub = 2**DIMENS ELSE NrSub = 4 END IF ! EpsAlg = ( ABS(LJob) == 2 ) CINFO%UNIFORM_SUBDIV = EpsAlg CINFO%NrSub = NrSub IF (( ABS(LJob) == 11) .AND. (DIMENS <= 3)) THEN ! simulate dcutri and dcutet ; NrSub = 2**DIMENS ; EpsAlg = .FALSE. CINFO%UNIFORM_SUBDIV = .TRUE. END IF IF ( ABS(LJob) == 12 ) THEN ! simulate dcuhre; NrSub = 2 ; EpsAlg = .FALSE. CINFO%NrSub = 2 END IF NRVERT = DIMENS + 1 ! Only cubes and simplices are implemented here. UINFO%NumFun = NumFun UINFO%NumRgn = NumRgn UINFO%MinPts = LMinPts UINFO%MaxPts = LMaxPts UINFO%EpsAbs = LEpsAbs UINFO%EpsRel = LEpsRel !----------------------------------------------------------------------- IF (LRestart) THEN ! This requires allocating larger arrays and copying ! the region collection. ALLOCATE(TmpRWork(SIZE(RWork)),STAT=status) IF (status /= 0) THEN WRITE(unit=*,fmt=*) "Problem allocating real workspace." STOP ! "Problem allocating real workspace." END IF ALLOCATE(TmpIWork(SIZE(IWork)),STAT=status) IF (status /= 0) THEN WRITE(unit=*,fmt=*) "Problem allocating integer workspace." STOP ! "Problem allocating integer workspace." END IF MAXRGN = DSUSED(IWork) CALL DSCOPY(IWork,RWork,TmpIWork,TmpRWork) ELSE MAXRGN = NumRgn END IF !----------------------------------------------------------------------- ! NRVACA is the number of regions the global adaptive algorithm ! removes from the data structure for further processing. ! In some routines for shared memory parallel machines ! this is the variable MDIV NRVACA = 1 ! MAXRGN depends on the number of function evalutions MAXRGN = MAXRGN + 1 + (NrSub-1)*(LMaxPts - RULCLS*NumRgn)/(RULCLS*NrSub) ! ! Compute length of workspace needed. ! BOTTIH = MAXRGN*(1+NIINFO) + 15 + NRVACA BLOCK = NRINFO+NRVERT*DIMENS+2*NumFun IF (NumFun > 1) THEN BLOCK = BLOCK + 1 END IF BOTTRH = MAXRGN*BLOCK ! ! Allocate space for the region collection ! IF (ALLOCATED(RWork)) THEN DEALLOCATE(RWork) END IF ALLOCATE(RWork(BOTTRH),STAT=status) IF (status /= 0) THEN WRITE(unit=*,fmt=*) "Problem allocating real workspace." STOP ! "Problem allocating real workspace." END IF IF (ALLOCATED(IWork)) THEN DEALLOCATE(IWork) END IF ALLOCATE(IWork(BOTTIH),STAT=status) IF (status /= 0) THEN WRITE(unit=*,fmt=*) "Problem allocating integer workspace." STOP ! "Problem allocating integer workspace." END IF ! ! Initialise region collection ! IF ( LRestart) THEN CALL DSCOPY(TmpIWork,TmpRWork,IWork,RWork) DEALLOCATE(TmpIWork,TmpRWork) ELSE IF ( MinCost > LMaxPts ) THEN Inform = 128 ! Dit nummer werd al gebruikt ! ELSE CALL DSINIT(DIMENS,NRVERT,NIINFO,NRINFO,NumFun,NRVACA, & BOTTIH,BOTTRH,IWork,Inform) END IF IF (Inform /= 0) THEN CALL Handle_Error(Inform,IFAIL) RETURN END IF END IF !----------------------------------------------------------------------- ! ! Call integration routine ! If (EpsAlg) THEN IF ( LRestart .AND. (PreJob /= ABS(LJob))) THEN Inform = 3 ELSE ! Observe that only relevant array sections are passed ! CALL Global_Adapt_Extrap(DIMENS,CINFO,UINFO,NRVERT,NIINFO, & NRINFO, Vertices(1:DIMENS,1:NRVERT,1:NUMRGN), & RgType(1:NUMRGN),Integrand,LRestart, & Value(1:NUMFUN),AbsErr(1:NUMFUN),LEval,Inform, & RWork,IWork,M) END IF ELSE IF ( LRestart .AND. (PreJob /= LJob)) THEN IF ( ASSOCIATED(M%RESLA)) THEN DEALLOCATE(M%RESLA,M%ERLARG,M%RESULT1,M%ABSERR1,M%RCOPY) END IF CALL DSPINT(IWork,RWork) CALL DSSUM(Value,Abserr,IWork,RWork,Inform) END IF ! Observe that only relevant array sections are passed ! CALL Global_Adapt(DIMENS,CINFO,UINFO,NRVERT,NIINFO,NRINFO, & Vertices(1:DIMENS,1:NRVERT,1:NUMRGN), & RgType(1:NUMRGN),Integrand,LRestart, & Value(1:NUMFUN),AbsErr(1:NUMFUN),LEval,Inform, & RWork,IWork) END IF IF (PRESENT(NEval)) THEN NEval = LEval END IF !----------------------------------------------------------------------- IF (LJob < 0) THEN WRITE(unit=*,fmt=*) "Debug mode: dumping region collection overview." CALL DSSTAT(IWork(:),RWork(:)) ! For debugging. END IF !----------------------------------------------------------------------- ! IF ((Inform >= 8) .or. (Inform == 3)) THEN ! Something went wrong but the data structure remains untouched ! and so this call can be ignored. IF ((Inform < 8) .AND. (Inform /= 3)) THEN PreJob = ABS(LJob) END IF CALL Handle_Error(Inform,IFAIL) RETURN END SUBROUTINE CUBATR_X SUBROUTINE CUBATR_1 & (DIMENS,Integrand,SVertices,SRgType,SValue,SAbsErr, & ! and optional parameters & IFAIL,Neval,EpsAbs,EpsRel,Restart,MaxPts,Key,Job) !----------------------------------------------------------------------- ! Input parameters ! ---------------- ! ! DIMENS Integer. ! The dimension of the region of integration. ! ! Integrand ! Externally declared function for computing all components ! of the integrand at the given evaluation point. ! It must have input parameter X: ! X(1) The x-coordinate of the evaluation point. ! X(2) The y-coordinate of the evaluation point. ! ... ! X(DIMENS) The z-coordinate of the evaluation point. ! and NumFun, the number of components of the integrand. ! It must be compatible with the following interface: ! INTERFACE ! FUNCTION Integrand(NUMFUN,X) RESULT(Value) ! USE Precision_Model ! INTEGER, INTENT(IN) :: NUMFUN ! REAL(kind=stnd), DIMENSION(:), INTENT(IN) :: X ! REAL(kind=stnd), DIMENSION(NUMFUN) :: Value ! END FUNCTION Integrand ! END INTERFACE ! ! SVertices ! Real array of dimension (DIMENS,DIMENS+1). ! Vertices(1:DIMENS,K) are the x, y, ... coordinates ! respectively of vertex K of the region, where ! K = 1,...,DIMENS+1. ! ! SRgType Integer. ! RgType describes the type of region L. ! ! SValue Real. ! Approximation to the integral if the procedure is restarted. ! ! SAbsErr Real. ! Estimate of the absolute error if the procedure is restarted. ! ! IFAIL Optional integer argument. ! This follows the NAG convention: ! IFAIL = 1 : soft silent error ! Control returned to calling program. ! IFAIL = -1: soft noisy error ! Error message is printed. ! Control returned to calling program. ! IFAIL = 0 : hard noisy error ! Error message is printed and program is stopped. ! Default IFAIL = -1. ! ! EpsAbs Optional real argument. ! Requested absolute error. ! Default EpsAbs = 0. ! ! EpsRel Optional real argument. ! Requested relative error. ! Default EpsRel = sqrt(machine precision). ! ! Restart Optional boolean argument. ! If Restart = FALSE, this is the first attempt to compute ! the integral. ! If Restart = TRUE, then we restart a previous attempt. ! In this case the only parameters for CUBATR that may ! be changed (with respect to the previous call of CUBATR) ! are MinPts, MaxPts, EpsAbs, EpsRel, Key and Restart. ! Default Restart = FALSE. ! ! MaxPts Optional integer argument. ! The maximum allowed number of integrand evaluations. ! Default MaxPts = enough to do 500 subdivisions. ! ! Key Optional integer argument. ! Can be used by Rule_General to choose between several ! local integration rules. ! Default Key = 2 if Dimension=1 and extrapolation is used ! (This corresponds to QAGS) ! Default Key = 0 otherwise ! ! Job Optional integer argument. ! If |Job| = 0, then nothing will be done except freeing all ! allocated memory. ! This is usefull after a call of CUBATR if no ! Restart will be done later and memory usage ! might become an issue later. ! Equivalently, one can call CUBATR() ! without any arguments. ! = 1, the global adaptive algorithm is called ! = 2, extrapolation using the epsilon algorithm is used. ! = 11, a region will be divided in 2**DIMENS subregions ! and the global adaptive algorithm is called. ! In combination with Key=0, this resembles DUCTRI and DCUTET. ! = 12, a region will be divided in 2 subregions ! and the global adaptive algorithm is called. ! In combination with Key=3 or 4, this resembles DCUHRE. ! If Job < 0, then an overview of the Region Collection is dumped. ! This will create the files tmp_integerstore and tmp_realstore. ! Default Job = 1. ! ! Output parameters ! ----------------- ! ! SValue Real. ! Approximation to the integral ! ! AbsErr Real. ! Estimate of the absolute error. ! ! NEval Optional Integer. ! Number of integrand evaluations used by CUBATR for this call. ! ! IFAIL Optional Integer. ! IFAIL = 0 for normal exit. ! ! AbsErr(K) <= EpsAbs or ! AbsErr(K) <= ABS(Value(K))*EpsRel with MaxPts or less ! function evaluations for all values of K, ! 1 <= K <= NumFun . ! ! IFAIL = 1 if MaxPts was too small to obtain the required ! accuracy. In this case Global_Adapt returns values of ! Value with estimated absolute errors AbsErr. ! ! IFAIL > 1 in more serious case of trouble. !----------------------------------------------------------------------- ! ! Global variables ! INTERFACE FUNCTION Integrand(NUMFUN,X) RESULT(Value) USE Precision_Model INTEGER, INTENT(IN) :: NUMFUN REAL(kind=stnd), DIMENSION(:), INTENT(IN) :: X REAL(kind=stnd), DIMENSION(NUMFUN) :: Value END FUNCTION Integrand END INTERFACE LOGICAL, OPTIONAL, INTENT(IN) :: Restart INTEGER, INTENT(IN) :: DIMENS,SRgType INTEGER, INTENT(OUT), OPTIONAL :: NEval INTEGER, INTENT(IN), OPTIONAL :: Key,MaxPts,Job INTEGER, INTENT(IN OUT), OPTIONAL :: IFAIL REAL(kind=stnd), INTENT(IN), OPTIONAL :: EpsAbs,EpsRel REAL(kind=stnd), DIMENSION(:,:), INTENT(IN) :: SVertices REAL(kind=stnd), INTENT(IN OUT) :: SValue,SAbsErr ! ! Local variables ! INTEGER, DIMENSION(1) :: RgType REAL(kind=stnd), DIMENSION(1) :: Value, AbsErr REAL(kind=stnd), DIMENSION(DIMENS,DIMENS+1,1) :: Vertices !------------------- RgType(1) = SRgType Vertices(:,:,1) = SVertices IF (PRESENT(Restart)) THEN IF ( Restart ) THEN Value(1) = SValue AbsErr(1) = SAbsErr END IF END IF CALL CUBATR & (DIMENS,1,Integrand,1,Vertices,RgType,Value,AbsErr, & ! and optional parameters & ifail=IFAIL,neval=Neval,epsabs=EpsAbs,epsrel=EpsRel, & restart=Restart,maxpts=MaxPts,key=key,job=Job) SValue = Value(1) SAbsErr = AbsErr(1) RETURN END SUBROUTINE CUBATR_1 SUBROUTINE CUBATR_CLEAR() IF ( ALLOCATED(Iwork) ) THEN DEALLOCATE(RWork,IWork) END IF IF ( ASSOCIATED(M%RESLA)) THEN DEALLOCATE(M%RESLA,M%ERLARG,M%RESULT1,M%ABSERR1,M%RCOPY) END IF PreJob = 0 RETURN END SUBROUTINE CUBATR_CLEAR SUBROUTINE CUBPACK_INFO() REAL(kind=stnd) :: x=1.0e-30 ! lowest accuracy of cubature formula constants print *," ---------------------------------------------------------------" print *," CUBPACK information" print *," -------------------" print *," The model for real numbers in the current installed version," print *," obtained with the declaration REAL(KIND=stnd), has the" print *," following characteristics:" print *," base = ",radix(x) print *," digits in this base = ", digits(x) ! print *," highest exponent = ", maxexponent(x) ! print *," lowest exponent = "minexponent(x), "(normalized numbers) print *," This implies:" print *," machine epsilon = ",epsilon(x) print *," largest real number = ", huge(x) print *," smallest normalized number = ", tiny(x) print * print *," The lowest relative error that may be obtained with this" print "("" version is about "",G8.2)",max(50*epsilon(x),x) print *," Asking for lower error will push the routine to use the" print *," maximal number of function evaluations it is allowed." print * print * print *," This version accepts a collection of hyper-rectangles" print *," (and parallelepipeds) and simplices as integration regions." print *," Extrapolation using the epsilon-algorithm is available" print *," for dimensions 1, 2 and 3." print *," The following values of KEY give different integration rules:" print *," - finite interval: KEY = 1, 2, 3, 4, 5." print *," KEY < 1 defaults to 1; KEY > 5 defaults to 5." print *," - n-cube: KEY = 3, 4 uses rule of degree 2*KEY+1" print *," otherwise, uses for a square a rule of degree 13" print *," 3-cube a rule of degree 11" print *," a rule of degree 7" print *," - n-simplex: KEY = 1, 2, 3, 4 uses rule of degree 2*KEY+1" print *," otherwise, uses for a triangle a rule of degree 13" print *," tetrahedron a rule of degree 8" print *," a rule of degree 7" print *," KEY = 0 corresponds to our preferred choice." print *," ---------------------------------------------------------------" RETURN END SUBROUTINE CUBPACK_INFO END Module CUI[/fortran]
Here is the part of the actual program that calls the interface:
[fortran]
MODULE math
  USE cui
!***************************************************[ CONSTANTS ]*****************************************************!
  REAL, PUBLIC, PARAMETER :: PI = 3.14159265358979
  REAL, PUBLIC, PARAMETER :: TWOPI = 6.28318530717958
  REAL, PUBLIC, PARAMETER :: SQRTPI = 1.77245385090552
!***************************************************[ VARIABLES ]*****************************************************!
  REAL, PRIVATE           :: gammafnarg      ! Argument of the gamma function
!***************************************************[ FUNCTIONS ]*****************************************************!
  PRIVATE :: Integrand
  PUBLIC  :: gammafn
  PUBLIC  :: betafn
  PUBLIC  :: factorial
  PUBLIC  :: linint
  PUBLIC  :: polint
  PUBLIC  :: polin2
  PUBLIC  :: spline, splint
  PUBLIC  :: deriv
  PUBLIC  :: zbrac
  PUBLIC  :: rtbis
!  PUBLIC  :: broydn
!  PUBLIC  :: lnsrch
  PUBLIC  :: logvec, linvec
  PUBLIC  :: addsubdev, productdev, quotientdev, powerdev, constdev
  PUBLIC  :: heavyside
  CONTAINS
!*************************************************[ GAMMA FUNCTION ]**************************************************!
  FUNCTION gammafn( x )
    REAL, INTENT( IN ) :: x                     ! Argument of the gamma function
    REAL               :: gammafn
    ! Local variables
    INTEGER, PARAMETER          :: n=1          ! Dimension of integration
    INTEGER, PARAMETER          :: rgtype=1     ! Region type
    REAL                        :: result      ! Result of integration
    REAL                        :: abserr       ! Absolute error on integration
    REAL, DIMENSION( 1:n, 0:n ) :: vertices
    REAL                        :: prod
    vertices( 1, : ) = (/ 0.0 , 1.0 /)          ! Boundaries of integration
    gammafnarg = x
    prod = 1.0
    ! Do some recursion if the argument is less than unity
    DO WHILE ( gammafnarg < 1.0 )
      prod = prod * gammafnarg
      gammafnarg = gammafnarg + 1.0
    END DO
    ! Do the integration...
    CALL CUBATR(n,Integrand,vertices,rgtype,result,abserr)
    gammafn = result / prod
    RETURN
  END FUNCTION gammafn
     USE Precision_Model
     Value( 1 ) = ( -LOG( x( 1 ) ) )**( gammafnarg - 1.0 )
END MODULE math[/fortran]
When I compile the first module, there is no problem. When I compile the module(s) that depend on implementing the interface CUBATR, I get the following error:
[plain]math.f90(74): error #6285: There is no matching specific subroutine for this generic subroutine call.   [CUBATR]
compilation aborted for math.f90 (code 1)
make: *** [math.o] Error 1
[/plain]
I suspect that the problem arises because the interface receives a parameter of varying size. What can you advese me about it? Do you need to see more code? Thanks!!
Module CUI
USE Precision_Model
USE internal_types
Implicit NONE
PRIVATE
!***BEGIN PROLOGUE CUBATR
!***DATE WRITTEN 901114 (YYMMDD)
!***REVISION DATE 970620 (YYMMDD)
!***REVISION DATE 980406 (YYMMDD) (MDIV removed)
!***REVISION DATE 000809 (YYMMDD)
!***REVISION DATE 010719 (YYMMDD)
!***REVISION DATE 020715 (YYMMDD) (CUBPACK_INFO added)
!***AUTHOR
! Ronald Cools, Dept. of Computer Science,
! Katholieke Universiteit Leuven, Celestijnenlaan 200A,
! B-3001 Heverlee, Belgium
! Email: [email protected]
!***PURPOSE Computation of integrals over a collection of regions.
!***DESCRIPTION
! CUBATR is the driver routine for CUBPACK and the only
! routine that a user has to deal with (at the moment).
! Module variables
INTERFACE CUBATR
END INTERFACE
CONTAINS
! Input parameters
! DIMENS Integer.
! NumFun Integer.
! Integrand
! INTERFACE
! END INTERFACE
! NumRgn Integer.
! Vertices
! the integral.
! allocated memory.
! Default Job = 1.
! Default Tune = 1.
! Output parameters
! MODULES USED
USE Check_Input
USE Error_Handling
! Global variables
INTERFACE
USE Precision_Model
END INTERFACE
! Named constants
! Local variables
! Check array sizes
Inform = 0
Inform = Inform + 1
END IF
Inform = Inform + 1
END IF
Inform = Inform + 1
END IF
Inform = Inform + 1
END IF
END IF
NEval = 0
END IF
LJob = Job
IF (Job == 0) THEN
CALL CUBATR_CLEAR()
RETURN
END IF
ELSE
LJob = 1
END IF
LRestart = Restart
ELSE
LRestart = .FALSE.
END IF
CINFO%Key = Key
ELSE
ELSE
CINFO%Key = 0
END IF
END IF
ELSE
END IF
RETURN
END IF
MinCost = RULCLS
DO i = 2,NumRgn
END DO
LMinPts = MinPts
ELSE
LMinPts = 0
END IF
LMaxPts = MaxPts
ELSE
END IF
CINFO%Tune = Tune
ELSE
CINFO%Tune = 1
END IF
LEpsAbs = EpsAbs
ELSE
LEpsAbs = 0
END IF
LEpsRel = EpsRel
ELSE
END IF
NrSub = 2**DIMENS
ELSE
NrSub = 4
END IF
CINFO%NrSub = NrSub
END IF
CINFO%NrSub = 2
END IF
IF (LRestart) THEN
END IF
END IF
ELSE
MAXRGN = NumRgn
END IF
NRVACA = 1
BLOCK = BLOCK + 1
END IF
DEALLOCATE(RWork)
END IF
END IF
DEALLOCATE(IWork)
END IF
END IF
IF ( LRestart) THEN
ELSE
ELSE
END IF
RETURN
END IF
END IF
If (EpsAlg) THEN
Inform = 3
ELSE
RWork,IWork,M)
END IF
ELSE
END IF
END IF
RWork,IWork)
END IF
NEval = LEval
END IF
IF (LJob < 0) THEN
END IF
PreJob = ABS(LJob)
END IF
RETURN
! Input parameters
! DIMENS Integer.
! Integrand
! INTERFACE
! END INTERFACE
! SVertices
! SRgType Integer.
! SValue Real.
! SAbsErr Real.
! the integral.
! allocated memory.
! Default Job = 1.
! Output parameters
! SValue Real.
! AbsErr Real.
! Global variables
INTERFACE
USE Precision_Model
END INTERFACE
! Local variables
RgType(1) = SRgType
IF ( Restart ) THEN
Value(1) = SValue
AbsErr(1) = SAbsErr
END IF
END IF
CALL CUBATR &
SValue = Value(1)
SAbsErr = AbsErr(1)
RETURN
END IF
END IF
PreJob = 0
RETURN
mecej4
You have removed some crucial lines of code that would have shown the context -- in particular, the USE CUBATR_MOD and the MODULE ... END MODULE ... statements in the second part.
That leaves insufficient information for me to give you a specific answer.
If, however, INTEGRAND and GAMMAFN are separate procedures rather than member procedures of a module, with GAMMAFNARG declared with module scope, INTEGRAND is seen as an ordinary integer variable within function GAMMAFN, and does not match with the interface for CUBATR, whose second argument should be: function returning real. That would explain the compiler error #6285.
aryangor
I have edited all code of both files in my first post - have a look now. To recap: the interface of the first file, CUBATR, is not implemented correctly in the second file, MATH - possibly the function INTEGRAND in the second file gives problems.
mecej4
Well, the code is now too big to analyse manually (without a compiler) but here is one thing to check:
You did not show what real(stnd) is; if it is double precision, then the array result in your math module, which is default (single) precision, will not match the interface for integrate. Make all the corresponding variables in the calls to integrate match in type -- either REAL or REAL(stnd), but not a mismatched mix.
aryangor
I modified the code as following (see lines 04-05 and 31-34):
[fortran]    ! Local variables
!    REAL      	                    :: result       ! Result of integration
    REAL(stnd)	                    :: result       ! Result of integration
    REAL                        :: prod
    gammafnarg = x
    prod = 1.0
    END DO
    RETURN
     USE Precision_Model
!     REAL, DIMENSION(:), INTENT(IN) :: X
!     REAL, DIMENSION(NUMFUN) :: Value
   END FUNCTION Integrand[/fortran]
Still, the same error persists, and even more - I get this one now:
[bash]math.f90(58): error #6683: A kind type parameter must be a compile-time constant.   [STND]
    REAL(kind=stnd)             :: result       ! Result of integration
[/bash]
I believe there is nothing to change in the first file. Did I understand you correctly?
aryangor
Ok I found something else.
[fortran]! This file is F-compatible, except for upper/lower case conventions.
MODULE Extended ! precision specification for real computations
! This requests the processor to use a real implementation 'stnd'
! which provides at least 20 decimal digits of precision and an
! exponent range of at least 10 ^ +- 80. It is expected that this
! precision may not be available on all machines.
! In July 2002, we found this available on
! SUN (Solaris) with f95
! IBM (AIX) with xlf90
! DEC alpha with f90
IMPLICIT NONE
Integer, PUBLIC, PARAMETER :: stnd = Selected_Real_Kind ( 20, 80 )
! A few computations are preferably done in higher precision 'extd'. The
! numbers chosen here should be such that the underlying hardware will
! select a higher precision for kind 'extd' than for kind 'stnd', if
! this is feasible. If a higher precision is not readily available,
! the same values may be used as are given above for 'stnd'. It is
! anticipated that on many machines, such an even higher precision may
! not be available.
Integer, PUBLIC, PARAMETER :: extd = Selected_Real_Kind ( 30, 80 )
end Module Extended[/fortran]
This is part of
[fortran]USE Precision_Model[/fortran]
call.
mecej4
I think that what you have posted has reached the limits of workability in a forum such as this. The code posted is rather large already, and incomplete in the sense that the pieces posted cannot be run through a compiler because many USED modules are missing.
Here are some bugs that I spotted:
(i) There are several instances where REAL variables are used in place of REAL(kind=stnd) variables and vice versa. There are several instances where scalar variables are used as equivalent to array variables with DIMENSION (1) or (1,1), in assignment statements and as actual arguments. These lax practices might have made it through Fortran 77 but with the stricter requirements in Fortran 9X, they need to be fixed.
(ii) The internal subprogram INTEGRAND has been used as an actual argument in a call to CUBATR. Section 12.1.2.2 of the Fortran Standard says "...the internal procedure name shall not be argument associated with a dummy procedure (12.4.1.3)".
(iii) CUBATR_1, which is a specific name for the generic name CUBATR, calls CUBATR (indirect recursion) without the specification RECURSIVE present for any procedure.
There are two ways to go forward. You can whittle down your code to a much smaller size and repost a complete example. Or you can take the files that I have attached, which compile without syntax errors and run, but have much code removed and have numerous cases of uninitialized variables. I have NOT addressed Bug (ii) above. You could add code to these to fill in the missing functionality, retaining the working variable types and subprogram interfaces.
TimP
Quoting mecej4
ifort supported this common extension to f90 even before it was included in 2003 standard.
mecej4
Tim, I am puzzled. I actually took the quote from the J4-007 draft of the F2003 Standard, from the link posted at the top of this forum. Was the restriction listed in the draft removed in the final standard (which I haven't bought so far)?
Hirchert__Kurt_W
New Contributor II
Quoting mecej4
I believe allowing internal procedures as actual arguments is a feature of the F2008 standard (which, despite its name, is still in the process of being formally approved). Tim may have either mistyped or misremembered.
-Kurt
aryangor
Thanks a lot, mecej4! I will have a good look into this - will let you know. Good day!
