Puzzling Compile error #6406
WSinc
Why do I get that for every variable in the COMMON block?
But I only get it when I include it in DERBOX, but not TERMV.
Yet, Both have the same INCLUDE statement.
I just can't see where I have declared anything more than once...
Doing a CLEAN first makes no difference.
Does the placement of the COMMON block make any difference?
Should it be in the same folder as the other routines?
I tried moving it around, made no difference.....
reinhold-bader
New Contributor II
by including obj001.cmn twice in derbox.F90, you have effectively declared the contained entities twice.
Reinhold
reinhold-bader
New Contributor II
Reinhold
WSinc
Yep, my bad...
I missed the 2nd include statement.
