Procedure Pointer Q2
dundar11
My previous post has two questions and I believe I couldn't state the problem well. Here is a more clear version of my problem.
Here is the test case:
[fortran]module procedure_pointer
  implicit none
 type, abstract :: parent_type
   real(8) :: tol
   procedure() , nopass, pointer :: func_pointer
 end type
 type ,extends(parent_type) :: child_type
   integer :: iter
 end type
 type function_type
  real(8) :: aux
  contains
  procedure,nopass :: func
 end type
contains
 function func(x) result(y)
 real(8) , intent(in) :: x
 real(8) :: y
 y=x*x
 end function
end module procedure_pointer
program procedure_pointer_test
  use procedure_pointer
  implicit none
  type(child_type) :: child
  type(function_type), target :: son
  real(8) :: func_result,x[/fortran]
[fortran]  x=3.2d0
   child%func_pointer=> son%func
  func_result=child%func(x)
  print*,'Function result :', func_result
end program procedure_pointer_test[/fortran]
And the compiler error is:
test.f90(34): error #8191: The procedure target must be a procedure or a procedure pointer. [FUNC]
test.f90(35): error #6460: This is not a field name that is defined in the encompassing structure. [FUNC]
test.f90(35): error #6158: The structure-name is invalid or is missing. [CHILD]
compilation aborted for test.f90 (code 1)
test.f90(34): error #8191: The procedure target must be a procedure or a procedure pointer. [FUNC] child%func_pointer=> son%func----------------------------^test.f90(35): error #6460: This is not a field name that is defined in the encompassing structure. [FUNC] func_result=child%func(x)--------------------^test.f90(35): error #6158: The structure-name is invalid or is missing. [CHILD] func_result=child%func(x)--------------^compilation aborted for test.f90 (code 1)
Ah, I see. You cannot assign a type-bound procedure as a function pointer. The target needs to be a component of the type or an external, module, dummy or intrinsic procedure (some limits on intrinsics.)
dundar11
I could assign a module procedure to this pointer and it works. But as you said I can't assign another type's bound procedure to that pointer...
so sad..
Is there any plan to implement this or it just doesnt make sense at all?
No, we won't be implementing that. It doesn't really make sense as the point of a type-bound procedure is typically that the derived type object gets passed as one of the arguments. With a pointer to it, what exactly are you passing?
dundar11
In my design
there will be two derived types
1- optimizer
2- cost function
optimizer will hold some settings for optimization algorithm and the implementation of the algorithm itself.
and a pointer for a costfunction
cost function is little bit more complex actually serves as a driver and there will be different cost functions.
so i want to design cost function as a derived type and this will help me to store some settings with it in a more compact way. On top of them I can manage these settings and during the runtime I tried to link
optimizers pointer to call costfunction derived types cost function. In this case I could chose which cost_function to use. Does it make sense?
But now I chose a different way:
I wrote a generic cost function in a seperate module which has different derived types for different cost function choices. With user's settings I can pick the correct cost function derived type.
I assigned generic cost function to optimizer's pointer and it works.
My main aim was to gain as much flexiblity as I can.
John4
Valued Contributor I
By using the NOPASS attribute in the type-bound procedure, you're actually saying that the components in the function_type derived type are not needed at all by func. So it seems that you want to design based purely on syntactic sugar ---i.e., just for the sake of invoking the function as something%func(x) instead of just func(x).
Instead of a procedure pointer, it seems that what you really want is a pointer to a derived type, so that child_type can still have access to the components of function_type:
    implicit none
    type function_type
        real(8) :: aux = 13
    contains
    end type
        real(8) :: tol
        class(function_type), pointer :: cost => NULL()
    end type
        integer :: iter
    end type
contains
        real(8) :: y
        y=x*x
    end function
    implicit none
    x=3.2d0
    child%cost=> son
    func_result = child%cost%func(x)
    print*,'Function aux :', child%cost%aux
