29280 Discussions
Procedure entry point__kmpc_free could not be located in the dynamic link library
fgarelli
Hi, i built the starter and the engine of openradioss but i cannot launch any job cause of this error: Procedure entry point__kmpc_free could not be located in the dynamic link library C:\tmp\openradioss\exec\starter_win64.exe
Any ideas of how to solve it?
Barbara_P_Intel
Does this answer help?
fgarelli
Hi Barbara, thank you for the answer.
I cannot enable the openMP library since I could not find any option in Visual Studio 2022 or through command line.
Do you have any suggestion of how to enable it? Hope this is going to solve the problem
Barbara_P_Intel
Compile and link with the compiler option: /Qopenmp.
jph
I'm getting the same error (point__kmpc_free) but DO have the compiler option set (Qopenmp) (VS Professional 2022
jph
also, I can run the code from inside the IDE, but am getting this error when I attempt to run it from the cmd line ...
