29642 Discussions
Procedure pointer implementations using module subroutines
Debanjan_Mukherjee
I have been trying to implement a procedure pointer based subroutine to do some numerical calculations. What I want to achieve is to be able to select different subroutines based on a choice variable using a select-case construct (each of these subroutines have the same interface). I have reproduced a representative example of this problem below.
module calculations
 implicit none
 subroutine model1(input1, input2, output)
 end subroutine model1
 subroutine model2(input1, input2, output)
 end subroutine
 subroutine model3(input1, input2, output)
 end subroutine model3
 subroutine calculate(modelChoice, output)
  implicit none
  integer, intent(in):: modelChoice
  double precision, dimension(3), intent(out):: output
  procedure(), pointer:: funcPoint => null()
  select case (modelChoice)
  case(1)
   funcPoint => model1
  case(2)
   funcPoint => model2
  case(3)
   funcPoint => model3
  case default
   funcPoint => model1
  end select
  call funcPoint(1,2,output)
 end subroutine calculate
end module calculations
I want to know whether I am doing this right. I ask this because when I use the procedure pointer implementations this way the input and output arguments don't get passed properly in the code. When I use their names directly then they work fine - which makes me think the subroutines themselves work fine individually. I can present a more verbose example of my code if needed - but can anyone tell me if I am doing this right ?
The general flow seems ok. It is critically important that the procedure pointers be declared as having an interface that matches that of the procedures being called. A compilable example would help us help you - I generally find that outlines and paraphrases leave out what's important.
Debanjan_Mukherjee
Would I need to declare an interface in this example ? If so, where would I declare it - in the module specification block, or inside the subroutine that uses the procedure pointers ?
I will condense and place a compilable example for this on the thread - but I feel as if the interface issue might be where I am going wrong, since I have no delcared interfaces in the code.
JVanB
Valued Contributor II
In your example I would change
to
procedure(model1), pointer:: funcPoint => null()
