29652 Discussions
Procedure target in structure constructor
ivanp
I would like to build a table of procedures. The program (copied below) fails to compile with the following error:
ifx: remark #10440: Note that use of a debug option without any optimization-level option will turnoff most compiler optimizations similar to use of '-O0'
/app/example.f90(39): error #6592: This symbol must be a defined parameter, an enumerator, or an argument of an inquiry function that evaluates to a compile-time constant.   [A]
type(pc), parameter :: table(3) = [pc(a),pc(b),pc(c)]  ! Doesn't work
I believe the program is legal. According to section 7.5.10 of J3/24-007, a procedure target is a valid component data source of a procedure pointer component of the derived type `pc`. Furthermore, a named procedure is a valid pointer initialization target in a constant expression, according to 10.1.12, bullet 3b.
Full program:
! dispatch_test.f90 --
!   Dispatch table using procedure pointers
module funcs
abstract interface
    function retchar()
       character(len=1) :: retchar
    end function
end interface
contains
    function a()
        character(len=1) :: a
        a = 'a'
    end function
    function b()
        character(len=1) :: b
        b = 'b'
    end function
    function c()
        character(len=1) :: c
        c = 'c'
    end function
end module
module dispatch_table
use funcs
implicit none
private
public :: table
public :: build_table, pc
! Procedure container
type :: pc
    procedure(retchar), pointer, nopass :: rc => null()
end type
! Static dispatch table
! According to J3/24-007, section 7.5.10, a procedure target
! can be used in the structure constructor.
contains
    ! Dynamic dispatch table
    function build_table() result(table)
        type(pc) :: table(3)
        table = [pc(a),pc(b),pc(c)]  ! This works
    end function
end module
program test
    use dispatch_table, only: pc, build_table
    implicit none
    table = build_table() ! Dynamic table
    associate(abc => &
        table(1)%rc()//table(2)%rc()//table(3)%rc())
        if (abc /= 'abc') stop 1
    end associate
    block
        use dispatch_table, only: table ! Static table
        associate(abc => &
            if (abc /= 'abc') stop 2
        end associate
    end block
    print *, 'PASS'
end program
Both the NAG Fortran compiler and flang accept this program.
Labels (2)
ivanp
Any opinions on this issue?
As I've tried to illustrate, the initialization of the (dynamic) dispatch table with:
is legal. The question is whether this statement is also valid as a constant expression in the initialization of a parameter variable.
Mark_Lewy
Valued Contributor I
This is one for the language lawyers
But, I note that compiling with gfortran 13.1.0 gives:
dispatch_test.f90:39:38:
39 | type(pc), parameter :: table(3) = [pc(a),pc(b),pc(c)] ! Doesn't work
| 1
Error: Parameter ‘a’ at (1) has not been declared or is a variable, which does not reduce to a constant expression
dispatch_test.f90:30:15:
30 | public :: table
| 1
Error: Symbol ‘table’ at (1) has no IMPLICIT type
dispatch_test.f90:55:9:
55 | use dispatch_table, only: pc, build_table
| 1
Fatal Error: Cannot open module file ‘dispatch_table.mod’ for reading at (1): No such file or directory
compilation terminated
Also, looking in John Reid's summary of the new features in Fortran 2023 (N2212.pdf), there doesn't appear to have been any relaxation on what you can have in initialisation expressions.
ivanp
I also asked the GNU contributors and they sent me here to ask for an opinion: https://gcc.gnu.org/bugzilla/show_bug.cgi?id=117070
For the record, also the tickets that saw this behavior fixed/introduced in NAG Fortran and LLVM flang were opened by me. For the Nvidia Fortran compiler (formerly PGI) I was recommended to use a dynamic dispatch table as a workaround.
It would be great if language lawyers could reach a verdict. Otherwise it is just one more unportable behavior.
Steve_Lionel
My take is that this is valid usage, though it does not astonish me that compilers get this wrong. Here's my logic:
R758 allows a proc-target as a component-data-source.
C7109 says "a proc-target shall correspond to a procedure pointer component.", which it does here.
R1041 says that proc-target can be a procedure-name
C1033 includes a module procedure in the list of allowed uses of a proc-target here
