29487 Discussions
Intel ifx 2025.1.0 - potential bug (runtime error) with Minpack
jvdp1
Dear,
The tests of [Minpack](https://github.com/fortran-lang/minpack.git) fail with the latest version of ifx `ifx 2025.1.0`, while they pass with previous versions (e.g., `ifx 2024.2.0`)
Code: https://github.com/fortran-lang/minpack.git (branch: main)
Compilation: fpm test --compiler ifx
OS: Fedora 40
Yours sincerely,
Jeremie
Labels (2)
jvdp1
Thank you!
After removing the options one per one, it is the option "-standard-semantics" that triggers the segfault on my OS.
andrew_4619
Maybe it would be worth elaborating on what happens and what is expected. I personally do not use git and would need learn how to use it. On windows:
ifx /c minpack.f90
Intel(R) Fortran Compiler for applications running on Intel(R) 64, Version 2025.1.0 Build 20250317
Copyright (C) 1985-2025 Intel Corporation. All rights reserved.
ifx /c minpack_capi.f90
It compiles OK with default options. Do I infer it is "bad" run time results? Anyway, as a forum user that is as far as I am going. I hope whatever issue gets resolved.
jvdp1
Thank you @andrew_4619 for testing it. Indeed, I can compile the whole project with ifx 2025.1.0, but the tests fail (see below). It is not the case with previous version of ifx or other compilers (ifort or gfortran).
Here are the commands used for compiling one of the tests of the project (on Linux):
```bash
ifx -c ././src/minpack.f90 -warn all -check all,nouninit -error-limit 1 -O0 -g -assume byterecl -standard-semantics -traceback -free -I././include -o src_minpack.f90.o
ifx -c ././src/minpack_capi.f90 -warn all -check all,nouninit -error-limit 1 -O0 -g -assume byterecl -standard-semantics -traceback -free -I././include -o src_minpack_capi.f90.o
ifx -c test/test_hybrj.f90 -warn all -check all,nouninit -error-limit 1 -O0 -g -assume byterecl -standard-semantics -traceback -free -I././include -o test_test_hybrj.f90.o
ar -rs libminpack.a src_minpack_capi.f90.o src_minpack.f90.o
ifx -warn all -check all,nouninit -error-limit 1 -O0 -g -assume byterecl -standard-semantics -traceback -I././include test_test_hybrj.f90.o libminpack.a -o t_hybrj
Running `t_hybrj` (similar with other tests), gives the following:
./t_hybrj
PROBLEM 1 DIMENSION 2
forrtl: severe (174): SIGSEGV, segmentation fault occurred
Image PC Routine Line Source
libc.so.6 00007F346A04EFD0 Unknown Unknown Unknown
Unknown 00007FFDCFD83DE0 Unknown Unknown Unknown
andrew_4619
OK helpful. I build and ran (windows) with my default settings in VS (Debug build). That seems to run to completion so the problem  is either OS or build option dependant. Have you tried with a debug build?
      INITIAL L2 NORM OF THE RESIDUALS  0.4919350D+01
      FINAL L2 NORM OF THE RESIDUALS    0.0000000D+00
      NUMBER OF FUNCTION EVALUATIONS          16
      NUMBER OF JACOBIAN EVALUATIONS           3
      EXIT PARAMETER                           1
      FINAL APPROXIMATE SOLUTION
       0.1000000D+01  0.1000000D+01
      INITIAL L2 NORM OF THE RESIDUALS  0.1340063D+04
      FINAL L2 NORM OF THE RESIDUALS    0.2886580D-13
      NUMBER OF FUNCTION EVALUATIONS           7
      NUMBER OF JACOBIAN EVALUATIONS           1
      EXIT PARAMETER                           1
      INITIAL L2 NORM OF THE RESIDUALS  0.1430001D+06
      EXIT PARAMETER                           1
      PROBLEM    2      DIMENSION    4
      INITIAL L2 NORM OF THE RESIDUALS  0.1466288D+02
      FINAL L2 NORM OF THE RESIDUALS    0.6046010D-34
      NUMBER OF FUNCTION EVALUATIONS         105
      NUMBER OF JACOBIAN EVALUATIONS           6
      EXIT PARAMETER                           4
       0.2695067D-17 -0.2695067D-18  0.3749757D-17  0.3749757D-17
      INITIAL L2 NORM OF THE RESIDUALS  0.1270984D+04
      FINAL L2 NORM OF THE RESIDUALS    0.5013400D-34
      NUMBER OF FUNCTION EVALUATIONS         124
      EXIT PARAMETER                           4
       0.2961048D-17 -0.2961048D-18  0.3392094D-17  0.3392094D-17
      INITIAL L2 NORM OF THE RESIDUALS  0.1268879D+06
      FINAL L2 NORM OF THE RESIDUALS    0.2112179D-33
      NUMBER OF FUNCTION EVALUATIONS         143
      NUMBER OF JACOBIAN EVALUATIONS          13
      EXIT PARAMETER                           4
      -0.1125674D-16  0.1125674D-17 -0.6482313D-17 -0.6482313D-17
      PROBLEM    3      DIMENSION    2
      INITIAL L2 NORM OF THE RESIDUALS  0.1065487D+01
      FINAL L2 NORM OF THE RESIDUALS    0.1712673D-08
      NUMBER OF FUNCTION EVALUATIONS         169
      EXIT PARAMETER                           1
       0.1098159D-04  0.9106147D+01
      INITIAL L2 NORM OF THE RESIDUALS  0.1000000D+01
      FINAL L2 NORM OF THE RESIDUALS    0.3744062D-07
      NUMBER OF FUNCTION EVALUATIONS           9
      EXIT PARAMETER                           1
      PROBLEM    4      DIMENSION    4
      INITIAL L2 NORM OF THE RESIDUALS  0.8550557D+04
      FINAL L2 NORM OF THE RESIDUALS    0.3983947D-10
      NUMBER OF FUNCTION EVALUATIONS          86
      NUMBER OF JACOBIAN EVALUATIONS           2
      EXIT PARAMETER                           1
      -0.9679740D+00  0.9471391D+00 -0.9695163D+00  0.9512477D+00
      INITIAL L2 NORM OF THE RESIDUALS  0.7349823D+07
      FINAL L2 NORM OF THE RESIDUALS    0.3771377D-09
      NUMBER OF FUNCTION EVALUATIONS         202
      NUMBER OF JACOBIAN EVALUATIONS           8
      EXIT PARAMETER                           1
      INITIAL L2 NORM OF THE RESIDUALS  0.7273070D+10
      FINAL L2 NORM OF THE RESIDUALS    0.3478935D-10
      NUMBER OF FUNCTION EVALUATIONS         386
      NUMBER OF JACOBIAN EVALUATIONS          35
      EXIT PARAMETER                           1
      PROBLEM    5      DIMENSION    3
      INITIAL L2 NORM OF THE RESIDUALS  0.5000000D+02
      FINAL L2 NORM OF THE RESIDUALS    0.2753440D-12
      NUMBER OF FUNCTION EVALUATIONS          18
      EXIT PARAMETER                           1
       0.1000000D+01 -0.1612103D-13  0.0000000D+00
      INITIAL L2 NORM OF THE RESIDUALS  0.1029563D+03
      FINAL L2 NORM OF THE RESIDUALS    0.2250995D-09
      NUMBER OF JACOBIAN EVALUATIONS           4
      EXIT PARAMETER                           1
       0.1000000D+01  0.1388617D-10  0.0000000D+00
      INITIAL L2 NORM OF THE RESIDUALS  0.9912618D+03
      FINAL L2 NORM OF THE RESIDUALS    0.7202777D-09
      NUMBER OF FUNCTION EVALUATIONS          37
      EXIT PARAMETER                           1
       0.1000000D+01  0.3234657D-10  0.0000000D+00
      PROBLEM    6      DIMENSION    6
      INITIAL L2 NORM OF THE RESIDUALS  0.6848587D+02
      FINAL L2 NORM OF THE RESIDUALS    0.3591108D-12
      NUMBER OF FUNCTION EVALUATIONS          60
      EXIT PARAMETER                           1
      -0.1572509D-01  0.1012435D+01 -0.2329916D+00  0.1260430D+01 -0.1513729D+01
       0.9929964D+00
      INITIAL L2 NORM OF THE RESIDUALS  0.3531259D+07
      FINAL L2 NORM OF THE RESIDUALS    0.3971695D-13
      NUMBER OF FUNCTION EVALUATIONS         140
      EXIT PARAMETER                           1
       0.9929964D+00
      PROBLEM    6      DIMENSION    9
      INITIAL L2 NORM OF THE RESIDUALS  0.8878955D+02
      FINAL L2 NORM OF THE RESIDUALS    0.5300605D-11
      NUMBER OF FUNCTION EVALUATIONS          92
      EXIT PARAMETER                           1
      -0.1530704D-04  0.9997897D+00  0.1476396D-01  0.1463423D+00  0.1000821D+01
      -0.2617731D+01  0.4104403D+01 -0.3143612D+01  0.1052626D+01
      INITIAL L2 NORM OF THE RESIDUALS  0.1015108D+08
      FINAL L2 NORM OF THE RESIDUALS    0.3823081D-01
      NUMBER OF FUNCTION EVALUATIONS         290
      NUMBER OF JACOBIAN EVALUATIONS          12
      EXIT PARAMETER                           4
       0.3119912D+00  0.1089342D+01  0.1379293D+01 -0.1175426D+02  0.6265968D+02
      -0.1636005D+03  0.2326239D+03 -0.1697823D+03  0.5076762D+02
      PROBLEM    7      DIMENSION    5
      INITIAL L2 NORM OF THE RESIDUALS  0.2257066D+00
      FINAL L2 NORM OF THE RESIDUALS    0.6045759D-12
      EXIT PARAMETER                           1
       0.8375126D-01  0.3127293D+00  0.5000000D+00  0.6872707D+00  0.9162487D+00
      INITIAL L2 NORM OF THE RESIDUALS  0.4117243D+07
      FINAL L2 NORM OF THE RESIDUALS    0.3782524D-10
      NUMBER OF FUNCTION EVALUATIONS         134
      NUMBER OF JACOBIAN EVALUATIONS          25
      EXIT PARAMETER                           1
       0.8375126D-01  0.5000000D+00  0.3127293D+00  0.9162487D+00  0.6872707D+00
      INITIAL L2 NORM OF THE RESIDUALS  0.5636130D+12
      FINAL L2 NORM OF THE RESIDUALS    0.1381501D-09
      NUMBER OF FUNCTION EVALUATIONS         244
      NUMBER OF JACOBIAN EVALUATIONS          47
      EXIT PARAMETER                           1
       0.6872707D+00  0.5000000D+00  0.8375126D-01  0.3127293D+00  0.9162487D+00
      PROBLEM    7      DIMENSION    6
      INITIAL L2 NORM OF THE RESIDUALS  0.2154720D+00
      FINAL L2 NORM OF THE RESIDUALS    0.1434346D-10
      EXIT PARAMETER                           1
       0.6687659D-01  0.3666823D+00  0.2887407D+00  0.7112593D+00  0.6333177D+00
       0.9331234D+00
      INITIAL L2 NORM OF THE RESIDUALS  0.1307925D+09
      FINAL L2 NORM OF THE RESIDUALS    0.9427397D-10
      NUMBER OF FUNCTION EVALUATIONS          91
      EXIT PARAMETER                           1
       0.9331234D+00  0.3666823D+00  0.6687659D-01  0.7112593D+00  0.2887407D+00
       0.6333177D+00
      INITIAL L2 NORM OF THE RESIDUALS  0.1875579D+15
      FINAL L2 NORM OF THE RESIDUALS    0.1953644D-09
      NUMBER OF FUNCTION EVALUATIONS         137
      NUMBER OF JACOBIAN EVALUATIONS          19
      EXIT PARAMETER                           1
       0.6687659D-01  0.7112593D+00  0.2887407D+00  0.9331234D+00  0.6333177D+00
       0.3666823D+00
      PROBLEM    7      DIMENSION    7
      INITIAL L2 NORM OF THE RESIDUALS  0.1837679D+00
      FINAL L2 NORM OF THE RESIDUALS    0.1935566D-09
      NUMBER OF FUNCTION EVALUATIONS          11
      EXIT PARAMETER                           1
       0.5806915D-01  0.2351716D+00  0.3380441D+00  0.5000000D+00  0.6619559D+00
       0.7648284D+00  0.9419309D+00
      INITIAL L2 NORM OF THE RESIDUALS  0.4269328D+10
      FINAL L2 NORM OF THE RESIDUALS    0.6180272D-10
      NUMBER OF FUNCTION EVALUATIONS         326
      NUMBER OF JACOBIAN EVALUATIONS          49
      EXIT PARAMETER                           1
       0.3380441D+00  0.2351716D+00  0.9419309D+00  0.7648284D+00  0.6619559D+00
       0.5806915D-01  0.5000000D+00
      INITIAL L2 NORM OF THE RESIDUALS  0.6414317D+17
      FINAL L2 NORM OF THE RESIDUALS    0.6655717D+13
      NUMBER OF FUNCTION EVALUATIONS          53
      EXIT PARAMETER                           4
      -0.4649136D+02 -0.1039521D+02 -0.7517577D+01  0.1217934D+02  0.4297678D+02
       0.2373113D+02  0.4306104D+02
      PROBLEM    7      DIMENSION    8
      INITIAL L2 NORM OF THE RESIDUALS  0.1965139D+00
      FINAL L2 NORM OF THE RESIDUALS    0.6440512D-01
      NUMBER OF FUNCTION EVALUATIONS          56
      EXIT PARAMETER                           4
       0.4985640D-01  0.1986351D+00  0.2698288D+00  0.4992723D+00  0.5007277D+00
       0.7301712D+00  0.8013649D+00  0.9501436D+00
      PROBLEM    7      DIMENSION    9
      INITIAL L2 NORM OF THE RESIDUALS  0.1699499D+00
      FINAL L2 NORM OF THE RESIDUALS    0.2699639D-08
      NUMBER OF FUNCTION EVALUATIONS          22
      EXIT PARAMETER                           1
       0.4420535D-01  0.1994907D+00  0.2356191D+00  0.4160469D+00  0.5000000D+00
       0.5839531D+00  0.7643809D+00  0.8005093D+00  0.9557947D+00
      PROBLEM    8      DIMENSION   10
      INITIAL L2 NORM OF THE RESIDUALS  0.1653022D+02
      FINAL L2 NORM OF THE RESIDUALS    0.1114710D-13
      EXIT PARAMETER                           1
       0.1000000D+01  0.1000000D+01  0.1000000D+01  0.1000000D+01  0.1000000D+01
      INITIAL L2 NORM OF THE RESIDUALS  0.9765624D+07
      FINAL L2 NORM OF THE RESIDUALS    0.8685322D-14
      EXIT PARAMETER                           1
      INITIAL L2 NORM OF THE RESIDUALS  0.9765625D+17
      FINAL L2 NORM OF THE RESIDUALS    0.1007921D-13
      NUMBER OF FUNCTION EVALUATIONS          17
      EXIT PARAMETER                           1
       0.9794303D+00  0.9794303D+00  0.9794303D+00  0.9794303D+00  0.9794303D+00
       0.9794303D+00  0.9794303D+00  0.9794303D+00  0.9794303D+00  0.1205697D+01
      PROBLEM    8      DIMENSION   30
      INITIAL L2 NORM OF THE RESIDUALS  0.8347604D+02
      FINAL L2 NORM OF THE RESIDUALS    0.1213683D-12
      EXIT PARAMETER                           1
      PROBLEM    8      DIMENSION   40
      INITIAL L2 NORM OF THE RESIDUALS  0.1280264D+03
      FINAL L2 NORM OF THE RESIDUALS    0.1115411D-12
      EXIT PARAMETER                           1
      PROBLEM    9      DIMENSION   10
      INITIAL L2 NORM OF THE RESIDUALS  0.2808058D-01
      FINAL L2 NORM OF THE RESIDUALS    0.2504524D-14
      EXIT PARAMETER                           1
      -0.4316498D-01 -0.8157716D-01 -0.1144857D+00 -0.1409736D+00 -0.1599087D+00
      -0.1698772D+00 -0.1690900D+00 -0.1552495D+00 -0.1253559D+00 -0.7541653D-01
      INITIAL L2 NORM OF THE RESIDUALS  0.5255526D+00
      FINAL L2 NORM OF THE RESIDUALS    0.1725833D-12
      EXIT PARAMETER                           1
      INITIAL L2 NORM OF THE RESIDUALS  0.1065739D+03
      FINAL L2 NORM OF THE RESIDUALS    0.4171303D-09
      NUMBER OF FUNCTION EVALUATIONS          42
      EXIT PARAMETER                           1
      PROBLEM   10      DIMENSION    1
      INITIAL L2 NORM OF THE RESIDUALS  0.1279297D+00
      FINAL L2 NORM OF THE RESIDUALS    0.2775558D-16
      EXIT PARAMETER                           1
      -0.1528139D+00
      INITIAL L2 NORM OF THE RESIDUALS  0.2562500D+01
      EXIT PARAMETER                           1
      -0.1528139D+00
      INITIAL L2 NORM OF THE RESIDUALS  0.8361172D+03
      NUMBER OF FUNCTION EVALUATIONS          15
      EXIT PARAMETER                           1
      -0.1528139D+00
      PROBLEM   10      DIMENSION   10
      INITIAL L2 NORM OF THE RESIDUALS  0.2518270D+00
      FINAL L2 NORM OF THE RESIDUALS    0.5018548D-14
      EXIT PARAMETER                           1
      INITIAL L2 NORM OF THE RESIDUALS  0.6116833D+01
      FINAL L2 NORM OF THE RESIDUALS    0.2188249D-12
      EXIT PARAMETER                           1
      INITIAL L2 NORM OF THE RESIDUALS  0.1269309D+04
      FINAL L2 NORM OF THE RESIDUALS    0.3043106D-14
      NUMBER OF FUNCTION EVALUATIONS          19
      EXIT PARAMETER                           1
      PROBLEM   11      DIMENSION   10
      INITIAL L2 NORM OF THE RESIDUALS  0.8411753D-01
      FINAL L2 NORM OF THE RESIDUALS    0.5296392D-02
      NUMBER OF JACOBIAN EVALUATIONS           7
      EXIT PARAMETER                           4
       0.5526154D-01  0.5695755D-01  0.5889067D-01  0.6113606D-01  0.6377856D-01
       0.6700482D-01  0.2079410D+00  0.1642671D+00  0.8643948D-01  0.9133506D-01
      INITIAL L2 NORM OF THE RESIDUALS  0.2030519D+02
      FINAL L2 NORM OF THE RESIDUALS    0.5916752D-10
      NUMBER OF FUNCTION EVALUATIONS          34
      NUMBER OF JACOBIAN EVALUATIONS           5
      EXIT PARAMETER                           1
       0.3439629D-01  0.3503232D-01  0.3571920D-01  0.3646522D-01  0.3728091D-01
       0.3817986D-01  0.3918014D-01  0.4030650D-01  0.1797202D+00  0.1562409D+00
      INITIAL L2 NORM OF THE RESIDUALS  0.9336937D+02
      FINAL L2 NORM OF THE RESIDUALS    0.1513404D-08
      NUMBER OF FUNCTION EVALUATIONS          44
      EXIT PARAMETER                           1
       0.1888395D+02  0.2516777D+02  0.1888528D+02  0.1888602D+02  0.1888684D+02
       0.1888774D+02  0.1888874D+02  0.1888986D+02  0.1902928D+02  0.1900580D+02
      PROBLEM   12      DIMENSION   10
      INITIAL L2 NORM OF THE RESIDUALS  0.2240213D+07
      FINAL L2 NORM OF THE RESIDUALS    0.5357531D-11
      NUMBER OF FUNCTION EVALUATIONS          21
      EXIT PARAMETER                           1
      INITIAL L2 NORM OF THE RESIDUALS  0.5223438D+08
      FINAL L2 NORM OF THE RESIDUALS    0.1259162D-09
      NUMBER OF FUNCTION EVALUATIONS          25
      EXIT PARAMETER                           1
      INITIAL L2 NORM OF THE RESIDUALS  0.1592365D+12
      EXIT PARAMETER                           1
      PROBLEM   13      DIMENSION   10
      INITIAL L2 NORM OF THE RESIDUALS  0.4582576D+01
      FINAL L2 NORM OF THE RESIDUALS    0.1493879D-07
      EXIT PARAMETER                           1
      -0.5707221D+00 -0.6818070D+00 -0.7022101D+00 -0.7055106D+00 -0.7049062D+00
      -0.7014966D+00 -0.6918893D+00 -0.6657965D+00 -0.5960351D+00 -0.4164123D+00
      INITIAL L2 NORM OF THE RESIDUALS  0.6391009D+03
      FINAL L2 NORM OF THE RESIDUALS    0.5192934D-08
      NUMBER OF FUNCTION EVALUATIONS          49
      EXIT PARAMETER                           1
      -0.5707221D+00 -0.6818069D+00 -0.7022101D+00 -0.7055106D+00 -0.7049062D+00
      INITIAL L2 NORM OF THE RESIDUALS  0.6333758D+05
      FINAL L2 NORM OF THE RESIDUALS    0.9878903D-10
      EXIT PARAMETER                           1
      PROBLEM   14      DIMENSION   10
      INITIAL L2 NORM OF THE RESIDUALS  0.1897367D+02
      FINAL L2 NORM OF THE RESIDUALS    0.2057897D-08
      EXIT PARAMETER                           1
      -0.4283029D+00 -0.4765964D+00 -0.5196525D+00 -0.5580993D+00 -0.5925062D+00
      -0.6245037D+00 -0.6232395D+00 -0.6213938D+00 -0.6204536D+00 -0.5864693D+00
      INITIAL L2 NORM OF THE RESIDUALS  0.1713092D+05
      FINAL L2 NORM OF THE RESIDUALS    0.7953613D-08
      EXIT PARAMETER                           1
      INITIAL L2 NORM OF THE RESIDUALS  0.1594986D+08
      FINAL L2 NORM OF THE RESIDUALS    0.4526431D-09
      EXIT PARAMETER                           1
1SUMMARY OF  55 CALLS TO HYBRJ1
 NPROB   N    NFEV   NJEV  INFO  FINAL L2 NORM
   1     2     16      3     1   0.0000000D+00
   1     2      7      1     1   0.2886580D-13
   1     2      7      1     1   0.0000000D+00
   2     4    105      6     4   0.6046010D-34
   2     4    124      6     4   0.5013400D-34
   2     4    143     13     4   0.2112179D-33
   3     2    169      6     1   0.1712673D-08
   3     2      9      1     1   0.3744062D-07
   4     4     86      2     1   0.3983947D-10
   4     4    202      8     1   0.3771377D-09
   4     4    386     35     1   0.3478935D-10
   5     3     18      3     1   0.2753440D-12
   5     3     20      4     1   0.2250995D-09
   5     3     37      8     1   0.7202777D-09
   6     6     60      6     1   0.3591108D-12
   6     6    140      6     1   0.3971695D-13
   6     9     92      4     1   0.5300605D-11
   6     9    290     12     4   0.3823081D-01
   7     5     10      1     1   0.6045759D-12
   7     5    134     25     1   0.3782524D-10
   7     5    244     47     1   0.1381501D-09
   7     6     13      2     1   0.1434346D-10
   7     6     91     13     1   0.9427397D-10
   7     6    137     19     1   0.1953644D-09
   7     7     11      1     1   0.1935566D-09
   7     7    326     49     1   0.6180272D-10
   7     7     53     12     4   0.6655717D+13
   7     8     56      8     4   0.6440512D-01
   7     9     22      2     1   0.2699639D-08
   8    10     11      2     1   0.1114710D-13
   8    10     11      2     1   0.8685322D-14
   8    10     17      2     1   0.1007921D-13
   8    30     12      2     1   0.1213683D-12
   8    40     12      2     1   0.1115411D-12
   9    10      6      1     1   0.2504524D-14
   9    10      9      1     1   0.1725833D-12
   9    10     42      1     1   0.4171303D-09
  10     1      6      1     1   0.2775558D-16
  10     1      8      1     1   0.2775558D-16
  10     1     15      1     1   0.2775558D-16
  10    10      6      1     1   0.5018548D-14
  10    10      9      1     1   0.2188249D-12
  10    10     19      2     1   0.3043106D-14
  11    10     60      7     4   0.5296392D-02
  11    10     34      5     1   0.5916752D-10
  11    10     44      4     1   0.1513404D-08
  12    10     21      1     1   0.5357531D-11
  12    10     25      1     1   0.1259162D-09
  12    10     38      2     1   0.0000000D+00
  13    10     11      1     1   0.1493879D-07
  13    10     49      1     1   0.5192934D-08
  13    10     22      2     1   0.9878903D-10
  14    10     20      1     1   0.2057897D-08
  14    10     25      2     1   0.7953613D-08
  14    10     38      2     1   0.4526431D-09
jvdp1
Thank you @andrew_4619 for your quick answer and tests. Indeed, you got the expected output.
To answer your question, I get the same issue with the two following builds/options:
  • debug:    -warn all -check all,nouninit -O0 -g -assume byterecl -standard-semantics -traceback
  • release:  -O3 -fp-model precise -pc64 -align all -reentrancy threaded -nogen-interfaces -assume byterecl -standard-semantics
Would you recommend another set of options?
andrew_4619
I tried a few options but don't get a crash, I suspect then it is operating system dependant,  You could try removing options to see if a particular option triggers the fault. You could also step through it to find where it crashes, the trace back you gave didn't show anything useful.
jvdp1
Thank you!
