Program crashes using polymorphic variables
Arjen_Markus
The program below crashes in the first iteration of QUICKSORT, using Intel Fortran 2015, whereas it works correctly (or perhaps more accurately: it produces the expected output) using gfortran .4.9.3. Wrt the first iteration: I inserted a write statement to see what part of the array is being handled. Only one line of output resulted - size = 10, then it crashed.
I wrote it as an answer to a question about generic programming in Fortran. It may be related to the use of polymorphic variables, as I have another version using sortable classes that does do the job fine (and gfortran produces a somewhat strange result). So I may have reached a boundary as far as today's compilers are concerned (well, newer versions do exist, so perhaps, "last night's compilers?)
! quicksort.f90 --
!     Implement a generic QUICKSORT
!     Numeric basic types and a sortable class supported
module quicksort_def
    implicit none
    type, abstract :: sortable
        !integer :: value
    contains
        procedure(assign_object), deferred        :: copy
        procedure(one_lower_than_two), deferred   :: lower
    end type sortable
    abstract interface
        subroutine assign_object( left, right )
            import                         :: sortable
            class(sortable), intent(inout) :: left
            class(sortable), intent(in)    :: right
        end subroutine assign_object
    end interface
    abstract interface
        logical function one_lower_than_two( op1, op2 )
            import                      :: sortable
            class(sortable), intent(in) :: op1, op2
        end function one_lower_than_two
    end interface
    interface operator(<)
        module procedure lower
    end interface
contains
! Generic part
logical function lower( op1, op2 )
    class(*), intent(in) :: op1, op2
    select type (op1)
        type is (integer)
            select type (op2)
                type is (integer)
                    lower = op1 < op2
            end select
        type is (real)
            select type (op2)
                type is (real)
                    lower = op1 < op2
            end select
        class is (sortable)
            select type (op2)
                class is (sortable)
                    lower = op1%lower(op2)
            end select
    end select
end function lower
subroutine copy( op1, op2 )
    class(*) :: op1, op2
    select type (op1)
        type is (integer)
            select type (op2)
                type is (integer)
                    op1 = op2
            end select
        type is (real)
            select type (op2)
                type is (real)
                    op1 = op2
            end select
        class is (sortable)
            select type (op2)
                class is (sortable)
                    call op1%copy( op2 )
            end select
    end select
end subroutine copy
recursive subroutine quicksort( array )
    class(*), dimension(:) :: array
    class(*), allocatable :: v, tmp
    integer               :: i, j
    i = 1
    j = size(array)
    allocate( v,   source = array(1) )
    allocate( tmp, source = array(1) )
    call copy( v, array((j+i)/2) ) ! Use the middle element
    do
        do while ( array(i) < v )
            i = i + 1
        enddo
        do while ( v < array(j) )
            j = j - 1
        enddo
        if ( i <= j ) then
            call copy( tmp,      array(i) )
            call copy( array(i), array(j) )
            call copy( array(j), tmp      )
            i        = i + 1
            j        = j - 1
        endif
        if ( i > j ) then
            exit
        endif
    enddo
    if ( 1 < j ) then
        call quicksort( array(1:j) )
    endif
    if ( i < size(array) ) then
        call quicksort( array(i:) )
    endif
end subroutine quicksort
end module quicksort_def
! test program
program test_quicksort
    use quicksort_def
    implicit none
    integer, dimension(10) :: int_array
    real, dimension(10)    :: real_array
    integer                :: i
    do i = 1,size(int_array)
        int_array(i)  = 11 - i
        real_array(i) = 11.0 - i
    enddo
    write(*,*) 'Sorting ...'
    call quicksort( int_array )
    call quicksort( real_array )
    write(*,*) 'Result:'
    write(*,'(i10)')   int_array
    write(*,'(f10.2)') real_array
end program test_quicksort
Amanda_S_Intel
Thanks for your report. I escalated this issue to the development team (DPD200376764).
FortranFan
The above code basically goes into an infinite loop in function named lower because of the overloaded intrinsic operation of "<" with a procedure containing two unlimited polymorphic arguments.  If one renames the defined operation to, say, .islessthan. and changes lines 102 and 105 to use this name, then the code runs fine.  I'm not convinced there is a compiler problem here; one just has to beware when one is dealing with unlimited polymorphism.
Separately, the abstract derived type "sortable" plays no role in the code as shown.  The particular test program of only default integer and real arrays can be made to work with simpler code:
! quicksort.f90 --
!     default integer and real supported
   implicit none
   private
   public :: quicksort
contains
      !.. argument list
      class(*), intent(inout) :: array(:)
      !.. local variables
      integer :: i
      integer :: j
      i = 1
      j = size(array)
      select type ( array )
         type is ( integer )
            blk_i: block
               integer :: v
               integer :: tmp
               include "i.f90"
            end block blk_i
         type is ( real )
            blk_r: block
               real :: v
               real :: tmp
               include "i.f90"
            end block blk_r
         class default
            !.. appropriate action elided
            !   need concrete design of sortable type to make use of it
      end select
      if ( 1 < j ) then
      end if
      end if
      return
Include file "i.f90":
      v = array((j+i)/2) ! Use the middle element
      do
            i = i + 1
         end do
            j = j - 1
         end do
         if ( i <= j ) then
            tmp = array(i)
            array(i) = array(j)
            array(j) = tmp
            i = i + 1
            j = j - 1
         end if
         if ( i > j ) then
            exit
         end if
      end do
! test program
   use quicksort_def
   implicit none
   integer                :: i
   enddo
   stop
Upon execution using Intel Fortran:
 Sorting ...
 Result:
         1
         2
         3
         4
         5
         6
         7
         8
         9
        10
      1.00
      2.00
      3.00
      4.00
      5.00
      6.00
      7.00
      8.00
      9.00
     10.00
Press any key to continue . . .
Arjen_Markus
I do not quite agree: I resolve the unlimited polymorphism using the select type construct. So within these type cases the compiler can and should choose the intrinsic operations, as it knows the actual type of the polymorphic variables.
I agree that the sortable class plays no role in the program as given - it was to illustrate how you could this for non-intrinsic types.
FortranFan
arjenmarkus wrote:
I do not quite agree: I resolve the unlimited polymorphism using the select type construct. So within these type cases the compiler can and should choose the intrinsic operations, as it knows the actual type of the polymorphic variables. ..
I guess this should come down to the standard - does it say explicitly say as such and if so, where?  I don't recall seeing it as such, so it'll be helpful to know it.  From what I remember, don't the rules for procedure overloading as described in the  standard effectively come down to the defined operation takes precedence over the intrinsic one?  Below is a simpler test case using which Intel development team can provide feedback on how the compiler should work in strict accordance with the standard and if there are aspects left up to the processor, how they want to approach it.
module m
   implicit none
   private
   end interface operator(<)
   public :: operator(<)
contains
   function lower( op1, op2 ) result(islessthan)
      !.. argument list
      !.. function result
      logical :: islessthan
      !.. local variables
      integer :: in1
      integer :: in2
      print *, " enter lower: "
      islessthan = .false.
      select type (op1)
         type is (integer)
            in1 = op1
            print *, " op 1 = ", in1
            select type (op2)
               type is (integer)
                  in2 = op2
                  print *, " op 2 = ", in2
                  islessthan = op1 < op2
            end select
         type is (real)
            select type (op2)
               type is (real)
            end select
         class default
      end select
   end function lower
end module m
program p
   use m, only : operator(<)
   implicit none
   islessthan = ( 0 < 42 )
   print *, " is 0 < 42? ", islessthan
   stop
end program p
Upon execution,
  op 1 =  0
  op 2 =  42
  enter lower:
  op 1 =  0
  op 2 =  42
  enter lower:
  op 1 =  0
  op 2 =  42
  enter lower:
  op 1 =  0
  op 2 =  42
  enter lower:
  op 1 =  0
  op 2 =  42
  enter lower:
  op 1 =  0
  op 2 =  42
  enter lower:
  op 1 =  0
  op 2 =  42
  enter lower:
  op 1 =  0
  op 2 =  42
  enter lower:
Arjen_Markus
Hm, my understanding is that defined operations cannot override operations defined for intrinsic types.
FortranFan
Here's some tidbit that may help Intel development team during their review.  Fortran 2008 standard (J3/10-007r1 WD 1539-1 2010-11-24) documentation says in section 12.4 Restrictions on generic declarations:
11 12.4.3.4.5 Restrictions on generic declarations
38 not all functions or not all subroutines. If a generic invocation applies to both a specific procedure from an
39 interface and an accessible intrinsic procedure, it is the specific procedure from the interface that is referenced.
Metcalf et al. in "Modern Fortran Explained" say in section 5.18:
"If a generic invocation is ambiguous between a non-intrinsic and an intrinsic procedure, the non-intrinsic procedure is invoked."
FortranFan
In a new thread on comp.lang.fortran related to the code in Message #5, IanH commented:
IanH wrote:
Note that paragraph starts "Within the scope of a generic name...".  An
operator is not a name.  The context for the text from Modern Fortran
Explained that you quoted is similar.
I think the standard should specify that you cannot override intrinsic
operations.  I see no benefit in permitting such operations to be
overridden by CLASS(*) dummy argument functions, but I see the
considerable possibility for lots of cost in terms of implementation and
language specification complexity.  I think the apparently ability to do
such an override is an oversight in the wording of the standard that has
arisen with the introduction of CLASS(*).
12.4.3.4.2 says in regards to defined operations that "...the types,
kind type parameters, or ranks of the dummy arguments shall differ from
those required for the intrinsic operation".  For the aspect of type,
instead of "differ" it should say something like "type shall not be
compatible".
I note that interp F08/0087 explicitly broke Fortran 95 compatibility in
order to squish the related possibility of overriding assignment of
intrinsic types.
Perhaps someone from the Intel team who interface with the standards committee can seek an interpretation and clarification on the current standard that may lead to a change in wording of the standard, assuming the standard did mean one "cannot override intrinsic
operations .. an oversight .. that has arisen with the introduction of CLASS(*)"?
But for Intel compiler, it would mean more than a change in wording but a fix to prevent such overrides.
But I'm not convinced this is just an oversight in the wording of the standard.  My hunch is the standard did mean to allow this, but the oversight is in not extending the INTRINSIC statement to include operators.  If one could do as shown in line 21 below, it will be a cleaner way to deal with such situations in my simple-minded thinking.
module m
   implicit none
   private
contains
      !.. argument list
      !.. function result
      intrinsic :: operator(<) !.. NOT SUPPORTED AT PRESENT, but it should be
      !.. local variables
      integer :: in1
      integer :: in2
      select type (op1)
         type is (integer)
            in1 = op1
            select type (op2)
               type is (integer)
                  in2 = op2
            end select
         type is (real)
            select type (op2)
               type is (real)
            end select
         class default
      end select
   end function lower
end module m
Amanda_S_Intel
Yes this does currently result in infinite recursion. The development team has decided that the compiler should instead be doing intrinsic less-than.
FortranFan
Amanda,
Thanks for the feedback.  Is it possible for the development team to provide some additional background on the rationale used for their decision?  Can they provide reference information in the Fortran standard that guided them toward the decision, or if this is a case where the standard pretty much leaves it up to the "processor", then where does it indicate so?  I ask because my own read of the standard suggests there is a gap when it comes to user overloads of intrinsic operations with unlimited polymorphic dummy arguments and what would be the consequent order of operations.  But I could be wrong; I don't have the patience and experience to interpret "standard speak".
At present, my sense is it will be very useful if the Intel reps on the Fortran standards committee can work with the committee to get clarification on this.  And if applicable, the committee can perhaps ponder over the value of extending the "INTRINSIC" statement to cover operators too, like I show in Message #8.  But if the development team does not think all this is necessary, then it will be good to understand why they think so i.e., which sections in the standard inform them on how this should be handled.
