I have been using digital fortran 6.1 successfully for a number of years on Windows NT. I upgraded to XP and reloaded Fortran. My old executables work fine. When I attempt to build a newexecutable (nothing has changed in the code)it compiles and builds fine, but when I try to run it I get the above error message. I reloaded my fortran once and the problem went away, but then came back. All subsequent attempts at reloading the program, building new workspces etc. have not solved the problem.
Do you get any warnings from the linker when you build the application? If so, what do they say?
This error can also come about from a corrupted EXE.
