Program will not load DLL
aelliott
I created a trivial DLL from the following code:
INTEGER(4) FUNCTION DUMMY(X)
!DEC$ ATTRIBUTES DLLEXPORT :: dummy
REAL(8) X
DUMMY = NINT(X)
RETURN
END FUNCTION DUMMY
This compiles and links fine as shown here:
C:\\projects\\GEWind\\loaddll>ifort -dll myfunc.f90
Intel Visual Fortran Intel 64 Compiler XE for applications running
on Intel 64, Version 12.0.4.196 Build 20110427
Copyright (C) 1985-2011 Intel Corporation. All rights reserved.
Microsoft Incremental Linker Version 9.00.21022.08
Copyright (C) Microsoft Corporation. All rights reserved.
-out:myfunc.dll
-dll
-implib:myfunc.lib
myfunc.obj
Creating library myfunc.lib and object myfunc.exp
I then built a trivial program to test the loading of a DLL:
PROGRAM testload
USE IFWIN
!DEC$ ATTRIBUTES DLLIMPORT :: dummy
! check to learn how to load and use a dll
INTEGER(HANDLE) dllhandle, ires
dllhandle = LoadLibrary('myfunc.dll'C)
write (*,*) ' DLL handle = ', dllhandle
END PROGRAM testload
This also compiles and links without a peep:
C:\\projects\\GEWind\\loaddll>ifort testload.f90
Intel Visual Fortran Intel 64 Compiler XE for applications running on
-out:testload.exe
-subsystem:console
testload.obj
Running testload, however, returns 0 for dllhandle and brings up a runtime error box:
R6034
An application has made an attempt to load the C runtime library incorrectly.
Please contact the application's support team for more information.
I can't figure out where the problem is. Anyone able to help?
Additional info: OS=Win7 pro, SP1, 64-bit
Visual Studio 2008, v9.0.21011.8 RTM
Fortran as shown above
Also tried it without the C qualifier on the file name - same results.
That error usually means that the program links to one of the MSVC DLLs (which a Fortran DLL will by default), but either the wrong version of that DLL is present or a local copy of the DLL (MSVCR90.DLL for example)
What does Dependency Walker say?
aelliott
Steve:
Thanks. depends gives a loading error. I am attaching the screen output, which seems to support your idea that mixed up DLLs are being referenced, but I am not sure how, since I am working from the command line and I did a full uninstall/reinstall of VS2008 and the compiler last Firday. There is no local copy of msvcr90.dll.
Andy Elliott
Well, Depends may not be giving the correct answer here because of the way PATH works - did you load the x64 version of Depends? Are you running your program from a "Intel 64" compiler build environment session?
aelliott
Steve:
Yes, I am running from a 64-bit build environment window. I downloaded the 64-bit version of depends and there the errors disappear and everything looks OK, I think? Fill attached as capture2.png.
Andy
Ah - try this. Set the Libraries > Use Runtime Library property of the executable to "Multithreaded DLL" and rebuild.
aelliott
I rebuilt the testload program based more closely on the example given in Samples diretory in DLL.zip. (I just discovered that in the v12 installation.) This includes a lot more code than would at first seem to be required, but after the rebuild, and following very carefully the build steps in the batch example, it does work. :)
So I recommend anyone else with similar problems also refer to that sample.
