ICE on unlimited polymorphism
Satish_BD
The following produces an Internal Compiler Error with ifort 12.0.3.174 on Ubuntu 10.10.
The trigger seems to be passing a null( ) as an actual argument to its corresponding dummy argument class(*).
Passing argument other than null() seems to work though.
======= begin test.F90 ==========
[fortran]module m_type
implicit none
type :: t_type
    real :: x
contains
    procedure :: eval_square
end type t_type
abstract interface
    real function real_function(object, point)
        class(*) :: object
        real, intent(in) :: point
    end function real_function
end interface
contains
    real function eval_square(self, x)
      class(t_type) :: self
      real, intent(in) :: x
      eval_square = x**2
    end function eval_square
    real function find_roots(func, approx, object)
      procedure(real_function) :: func
      real, intent(in) :: approx
      class(*), optional :: object
      find_roots =  func(object, approx)
    end function find_roots
end module m_type
program main
use m_type
implicit none
type(t_type) :: t
real :: root root = find_roots(eval_square, 10.0, null()) ! Replace null() by 't' and the ICE is gone ! end program main [/fortran]
======= end test.F90 ==========
I couldn't reduce it to a simpler testcase, but I think this is small enough.
-- Satish.BD
Thanks for reporting this problem. The use of NULL() as an actual argument where the dummy argument is OPTIONAL is a feature that is new in Fortran 2008 and which Intel Fortran does not yet support. If you remove the null() argument it works as you expect.
I'll report the issue of the ICE, which is always wrong, but I suggest that you remove the null() argument for now and just pass two arguments. Issue ID for the ICE is DPD200168881.
Fixed in a future release.
