matmul() thread safe?
dnoack
I have some trouble with the intrinsic function matmul() in case of parallel prcessing using threads. I use ifort 10.1.021 .
If I run the program sequentially with 1 tread, it works fine.
If I use more than 1 threads it crashes with different errors, e.g.:
Generating Traceback ...
Using host libthread_db library "/lib64/tls/libthread_db.so.1".
Program terminated with signal 11, Segmentation fault.
#0 0x0000002aa0bf8e1c in pthread_mutex_lock () from /lib64/tls/libpthread.so.0
#1 0x0000002a9fe16a1e in thr_Mutex::Lock ()
I have the suspicion that this lies on matmul() and have overloaded the intrinsic function with an own function and this works also fine. So I think the reason of the problem is the intrinsic matmul().
I am aware, that the intrinsic matmul() is highly optimized and my own function is rather poor. Since my program were used in the field of scientific calculations, I have to pay attention to the cpu-time.
This arises the following questions:
1. Have anyone also problems with the threadsafeness of matmul()?
2. Is there an workaround that not significantly degrade the performance?
Best regards
dieter
jimdempseyatthecove
Your program may require larger stack size. See environment variable KMP_STACKSIZE. This sets the stack size for the additional threads, There is also a linkeroption to set the stack size of the application's main thread.
Jim Dempsey
