Is it possible to programmatically check compiler switches? For example, to see if /assume:minus0 is set, is invoking sign flipping with the SIGN intrinsic the only way to do it? I guess there is no way to change it on the fly.
TIA,
Gerry T.
TIA,
Gerry T.
There's nothing in the executable you can query directly.
Steve
Steve
OK.
But why, if /assume:minus0 on an Intel processor, does
sign(0.d0, -0.d0) = sign(-0.d0, -0.d0) (= 0.d0)? I would expect the two to differ by a sign or is an identically zero argument special?
Gerry T.
Gerry T.
