29642 Discussions
Programmatically checking compiler switches.
gfthomas8
Is it possible to programmatically check compiler switches? For example, to see if /assume:minus0 is set, is invoking sign flipping with the SIGN intrinsic the only way to do it? I guess there is no way to change it on the fly.
TIA,
Gerry T.
Steven_L_Intel1
There's nothing in the executable you can query directly.
Steve
gfthomas8
OK.
But why, if /assume:minus0 on an Intel processor, does
sign(0.d0, -0.d0) = sign(-0.d0, -0.d0) (= 0.d0)? I would expect the two to differ by a sign or is an identically zero argument special?
Gerry T.
