Programming modules
jaeger0
Hi
I'm writing on a bigger project, where I use an amount of modules, so sometimes I got problems to check the dependenciy.
Usually I include the required modules only in the functions of the module itself. So checking the dependencies, I have to go through all functions of the module.
However it would be nice if I just include all required modules in the head of the module(I'm currently programming).
I know, this is possible, but however makes the compiler any difference in it. So is there a difference if i include all required modules in the head of the module, or if I include the corresponding modules only in the subroutines, where they are required ?
Thanks for any comments
Martin
It is a better programming practice to USE only those modules you need. As for the compiler, the fewer modules it has to read during compilation, the faster it can compile.
