29389 Discussions
Programs compiled with ifx are slower than compiled with ifort.
eliopoulos
Programs compiled with ifx are slower than compiled with ifort. Is this going to change with the future updates? Speed is very important to me and now ifort has been discontinued.
Ron_Green
Perhaps you can share the compiler options you used, and the Intel processor you are targeting with -x or -ax, and if you can, share the sources.
eliopoulos
I don't know where to find the compiler options you need. I use two different Intel processors: core i9 14900ks and core i7 1260p. I don't understand the -x and -ax thing. I compile from the Visual Studio Community 2022. I don't want to share the program in public but I could send it with e-mail.
Ron_Green
You can look in Project Properties for your Release Configuration and x64 configuration.  The processor targeting will look like this:
eliopoulos
This is what I use:
eliopoulos
Is there anything I can do to accelerate my programs compiled with ifx?
Mark_Lewy
Valued Contributor I
Without knowing your compiler options, it's difficult to say what might be causing this.  I suggest you share the Fortran command line from the project properties.  For example,
One thing I noted, when we ported to ifx,  was that if you use /standard-semantics it degrades floating point performance significantly with IFX because it sets /assume:ieee_compares.  You could (like us) add /assume:noieee_compares as an additional option.
Our application generally runs faster or at similar speeds to ifort when built with ifx, depending on workload.
Also, check out the porting guide from ifort to ifx: Porting Guide for ifort Users to ifx and see if anything in there helps.
eliopoulos
My compiler options:
I tried to add /assume:noieee_compares and the program remains slower than compiled with ifort.
Mark_Lewy
Nothing obvious stands out here.  I'd suggest profiling your program with vTune to see where the hotspots are.
Ron_Green
What you showed does not match the recommendation I had for using -x or -ax options.  This is called out in the Porting Guide
https://www.intel.com/content/www/us/en/developer/articles/guide/porting-guide-for-ifort-to-ifx.html
under the section on CPU performance:
-O2 Add -x<code> to enable all available Intel optimizations and advanced vectorization. Add -xHost to enable those optimizations the platform where you are compiling.
O2 is NOT enough for ifx.  It was for ifort.  With ifx, you only get Intel proprietary optimizations IF you include -xhost or -x<arch> or -ax equivalents.
This is something I am hearing from customers.  They got used to simply using O2 with ifort and are unaware that they have to use O2 and -x<something> with ifx.  I recommend -O2 -xhost.  Try that.
eliopoulos
How can I set: -O2 -xhost?
Ron_Green
O2 will be set by using Release Configuration.  Here is where to find setting /Qxhost
eliopoulos
ifort remains 20-30% faster.
Ron_Green
Is it possible for you to Clean the project, then zip up the entire solution directory and attach it here?
One other question - is the primary data type REAL, REAL (kind=8), or COMPLEX ?
eliopoulos
The primary data type is double precision.
Ron_Green
Thanks for the files.  But nlay.txt is zero length and it causes the program to exit (end of file during read).  Can you attach a good nlay.txt file?
eliopoulos
Here it is.
eliopoulos
Any news?
TobiasK
@eliopoulos thanks for sharing the code. However, your code is quite complex and it will take a while for us to figure out where something is going wrong. If you have purchased priority support, we will treat this with higher priority, but I don't see an entry for you. If you can extract smaller code samples the process on our side is also a lot faster. You may start with Vtune to compare the binaries generated with IFORT/IFX and see where the performance drop comes from. If you need help with Vtune, please ask here:
https://community.intel.com/t5/Analyzers/bd-p/analyzers
Ron_Green
@eliopoulos I will get to this issue today.  There was a US Holiday Thursday and Friday.  Monday I have been catching up on backlog.
Ron_Green
I need ALL the .txt files.  Here is a list from the code - are there others missing?
open(2,file='laminate.txt')
do i=1,nl
read(2,*)mat(i),thick(i),angled(i)
enddo
close(2)
do i=1,nl
angle(i)=angled(i)*pi/180.0d0
enddo
zk(1)=-sum(thick)/2.0d0+thick(1)/2.0d0
if (nl>1) then
do i=1,nl-1
zk(i+1)=zk(i)+thick(i)/2.0d0+thick(i+1)/2.0d0
enddo
else
endif
open(3,file='Nx.txt')
read(3,*)FtNx
close(3)
open(4,file='Ny.txt')
read(4,*)FtNy
close(4)
open(5,file='Ns.txt')
read(5,*)FtNs
close(5)
open(6,file='Mx.txt')
read(6,*)FtMx
close(6)
open(7,file='My.txt')
read(7,*)FtMy
close(7)
open(8,file='Ms.txt')
read(8,*)FtMs
close(8)
