Project Property sheets for a fortran dll or exe
philippe_bernier
Hi everyone,
I am trying to see if there is any way to use the Visual Studio "Project Property sheet" feature and define some environnement variables for my fortran projects. I have a solution with both C++ and Fortran projects. I can see options to add / modify those project property sheets for the C++ but the fortran projects are not listed and hence, I cannot add a property sheet for those projects. I am using Fortran Composer XE 2011.
Thank you
Philippe
Steven_L_Intel1
Fortran does not use "property sheets", but you can define environment variables on the Debug property page of a Fortran project.
philippe_bernier
Thank you for your answer :-)
