29487 Discussions
Purchase of intel fortran, intel visual fortran
KYLam
Hi, I am developing some fortran programs for my structure design work. Now, I need to do some graphic presentation.
I come across that there are "intel fortran" and "intel visual frotran". Are these two the same one or two different softwares and I have to purchase both? Where can I do the purchase?
By the way, I am working on a 64bit personal computer.
KYLam
AndrewG_Intel
Hello @KYLam
We understand that you have some inquiries regarding Intel® Fortran. We have a forum for those specific products and questions so we are moving it to the Intel® Fortran Compiler Forum so it can get answered more quickly.
Andrew G.
Steve_Lionel
On Windows, these are the same thing. You don't have to purchase anything as the Intel Fortran compiler is now free on all platforms. It is a component of Optimized Tools for HPC Apps Using Intel® oneAPI HPC Toolkit . On Windows you will need Microsoft Visual Studio 2019 with C++ Desktop Application support installed. (Installing Microsoft Visual Studio* 2019 for Use with Intel® Compilers). You can choose to buy a support license, giving you access to Intel support engineers.
KYLam
Steve,
Thanks for your info.
I will try.
cean
New Contributor II
Interested. I am in the beginning of adding GUI for my structure design with Intel Fortran.
KYLam
I have installed the intel FORTRAN. I tried to compile a simple program in command line.
In the "intel(r) oneAPI Tools" window, I change the subdirectory to where I have the file by entering:
cd c:\documents\iforttry
at this subdirectory, I entered as follow:
c:\Documents\iforttry> ifort trybackspace.for
the compiler compiled the program and created trybackspace.obj in my subdirectory but didn't link. It give a message as:
link: invalid option -- s
What had I done wrong?
mecej4
The message
is probably an indication that you have a program called "link.exe" other than the MS linker, which is also called "link.exe". This can happen if you have Cygwin installed, in which its link.exe is for creating file links, not for linking OBJ files and libraries into EXEs and DLLs. Check %PATH% and make sure that the directory containing the MS linker appears before any other directory that also contains a LINK.EXE.
DavidWhite
Valued Contributor II
Suggest that you get Visual Studio Community Edition (2019).  You will need to rerun the Fortran installer to get the VS integration working.
Then you create your projects within a Visual Studio solution, and the compilation can all be done through VS.
If you wish to run from the Command Window, make sure you are using the appropriate link provided during the Fortran install - this ensures that all the required paths for Fortran are set.  They are not set if you simply open a normal window.
Soumya_M_Intel
Hi KYLam,
We apologize for the delay. We understand that the current concern is a post-installation issue. However, do correct us know if that is wrong.
Proceeding further, we are routing this thread to the correct forum for further assistance. Our internal team will get back to you there promptly.
Soumya
