Puzzling compiler message
WSinc
The following routine calls itself recursively -
I get a WARNING message about incompatible argument types,( line 11)
I don't understand this, since isq+1 and isq are both integer(1), and
inum1 and inum are both integer(1) as well.
Do you have any idea why I would see this?
Would it think that isq+1 is a different type?
Of course I could say: isq1=isq+1, then pass that along, if isq1 is also integer(1).
IanH
isq may be integer(1), but the literal constant `1` is default integer - that is integer(4) for ifort.  When you add two integers together that are of mixed kinds, the result of the expression has the kind that has the greatest decimal exponent range.  Again, out of integer(1) and integer(4) it is integer (4) that has the greatest range.
Hence `isq + 1` is of integer(4), hence you have a kind mismatch.
`isq + 1_1` however...
WSinc
OK, I could also say Isq+1_1 as you suggested.
But there is still the possibility of an integer overflow.
For example, suppose I said isq*127_1. The result is very likely to be WRONG, since it cannot be higher than 127.
So would it be better to change the argument to integer(2)?
Or is there an easy way to check for integer overflow? As far as I know you cannot turn on an overflow trap, you have to
insert checks for that explicitly.
There is not currently a way to check for integer overflow. Is there a reason you've chosen a small kind here? Typically you do this only when accessing data structures defined with small integers. Otherwise you'll get better performance sticking to default integer kind.
WSinc
Well, I reasoned that when doing VERY LARGE numbers of operations, the processing time would be reduced by comparing smaller
sized integers. Otherwise the default would be Integer(4).
But maybe this isn't strictly correct. It depends upon whether it STARTS with the least significant byte, or the MOST significant one.
The comparison might take 4 times as long with 4 byte integers, if the first three byte are all zeros in most cases.
This might also hold for ordinary operations, like + - / or * for example.
It would be interesting to run some test cases, see what the outcome is.
WSinc
Here is a little run-time test case:
Contrary to what I said, I get really surprising results.
I don't see why taking comparisons of different integer sizes would give LONGER
CPU times for shorter integers.
But apparently that's the case. Run this yourself, see if you get the same thing.
When I run it repeatedly, I get pretty consistent answers
Each one of the three cases does 4 billion (roughly) comparisons - - 2**32 in fact.
I hope this gives a fairly reliable measure of actual CPU time.
That's because the processor is optimized for default integer sizes. It actually takes longer to compare shorter integers.
