use NNLPF or NNLPG in fortran IMSL
Abac1
In NNLPF, the constrained nonlinear optimization problem is cast into the manner of "SELECT CASE ". CASE (0) corresponds to the objective function evaluation, while CASE (1:ME) for equality constraints and CASE(ME+1:M) for unequality contraints.
If ME/M is a small number, say less than 5, we can easily write the constraints one by one in the same way as the documentation examples (Ch 8 Optimization of the IMSL documentation). However, What if ME/M is considerably large as 1000, are there any better ways to write these constraints? For example, is it possible to write the constraints via matrix? Thanks in advance.
mecej4
IMSL cannot and does not define what is and what is not legal Fortran. The Fortran standard does, and the compiler claiming standard conformance implements that definition.
The CASE-selector-block construct in Fortran allows the selector to be an initialization expression or even something such as
CASE (1, 2, 7, 10:17, 23)
You are not even required to use a SELECT construct. You can use a matrix, use binary search, or whatever you please, as long as your code does what IMSL wants it to.
Abac1
Hi mecej4:Thank you for the ideas.
I tried to put my concerns into an example here. The example is adapted from example 2.8.1, pp.15-17 of Floudas's book "A Collection of Test Problems for Constrained Global Optimization Algorithms". You may find it from google book as well. (http://books.google.com.sg/books?id=zRIfcNQ0V04C&pg=PA5&lpg=PA5&dq=a+collection+of+ch2+Quadratic+Programming+test+problems&source=bl&ots=1Hh-VYhFGj&sig=cU0J89l9e_NnG11ZnDqZavyMgyo&hl=en&sa=X&ei=LxLYT8iFFsTZrQe9ueDmDw&ved=0CEQQ6AEwAA#v=onepage&q=a%20collection%20of%20ch2%20Quadratic%20Programming%20test%20problems&f=false)
I put them into the attached files called "NonOptEx1". There are a pdf file (http://software.intel.com/file/44390) and Fortran90 source file (http://software.intel.com/file/44391) inside. I have two problems with this example:
1. I cannot get the indicated solution
2. If possible, a better way coding it in Fortran should be: [min f(x)=AX^2+BX, subjected to CX=D].
In the attached source code, the problem is programmed straightforward and not good enough, especially the way of handling the constraints. I am looking for simple ways to formulate the constraints in a matrix form. Could you help to look into my attached code to make it more concise? Thanks a lot.
huang_l_
i am a new learner about IMSL and i also have a similar question here.
No.1 i write my FCN subroutine as following:
SUBROUTINE FCN1 (X, IACT, RESULT, IERR)
INTEGER IACT
REAL(KIND(1E0)) X(*), RESULT
LOGICAL IERR
SELECT CASE (IACT)
CASE(0)
RESULT = (X(1)-2.0E0)**2 + (X(2)-1.0E0)**2
CASE(1)
RESULT = (X(1)-1)**2*(X(1))**2
!CASE(2)
!RESULT = -(X(1)**2)/4.0E0 - X(2)**2 + 1.0E0
END SELECT
RETURN
END
and i call the NNLPF in my main program like this:
   EXTERNAL FCN1
   INTEGER::M, ME
   REAL(KIND(1E0)) FVALUE, X(5), XGUESS(5), XLB(5), XUB(5)
    M=1
    ME=1
    XLB = -HUGE(X(1))
    XUB = HUGE(X(1))
    CALL NNLPF (FCN1, M, ME, IBTYPE, XLB, XUB, X,IPRINT=1)
    !DO i =1,size(X)
    !    write(*,'(F4.0)')X(i)
    !END DO
    CALL WRRRN ('The solution is', X)
as you see,my object function is "min f=(x1-2)^2+(x2-1)^2" and i only have one equality  constraint:(x1-1)^2*x1^2=0; the optimal solution i think is x1=1.0,x2=1.0,and the minimun f=1.0.
but the indicated result is x1=0.0,x2=1.0,min f =4.0,as show in the attachments.
i don't know why?
No.2 if i don't know the number of equality constraints and uneqaulity constraints, and even the size of variable X, or some other linear constraints bounds ,when i write my FCN subroutine. it just decided by  input files read from the main program .then how can  write my FCN subroutine? in other words, how can i pass the optimization dimension and the constraints bounds parameter to my FCN?
thanks a lot!
mecej4
The majority of nonlinear constrained optimization solvers are local optimizers. Their success often depends on your giving them good starting values and well-behaved functions in the objective and constraint functions. In your case, you seem to seek a global optimum, yet you gave no starting guess for X(1:2). The IMSL manual states "A good initial starting point is very problem specific and should be provided by the calling program whenever possible.  See optional argument  XGUESS.". You can also help move the optimizer towards the region of the more desirable solution by specifying additional constraints. For example, try x1 >= 0.001.
What was the reason for specifying the constraint as [(x- 1) x2]2 = 0 instead of simply (x- 1) x2 = 0 ?
huang_l_
What was the reason for specifying the constraint as [(x- 1) x2]2 = 0 instead of simply [(x- 1) x2] = 0 ?
okay, your answer is very helpful! but what about the question NO.2
"if i don't know the number of equality constraints and uneqaulity constraints, and even the size of variable X, or some other linear constraints bounds ,when i write my FCN subroutine. it just decided by input files read from the main program .then how can write my FCN subroutine? in other words, how can i pass the optimization dimension and the constraints bounds parameter to my FCN?"
thanks very much!
mecej4
In situations where the argument list (specified by IMSL for the user function FCN) is not adequate, you can supplement it by using module variables (or, in the old days, using COMMON blocks). Be aware, however, that hiding information from the optimization routine can often cause failure to obtain a solution.
Here is an example, which I constructed by extending the example given in the IMSL manual for NNLPF.
    MODULE sharedvars
       IMPLICIT NONE
       INTEGER :: n, m = 2, me = 1, ibtype = 0
    END
    PROGRAM xnnlpf
       USE nnlpf_int
       USE wrrrn_int
       USE sharedvars
       IMPLICIT NONE
       REAL fvalue
       REAL, ALLOCATABLE :: x(:), xguess(:), xlb(:), xub(:)
       INTEGER i
       EXTERNAL fcn
       READ (*, *) n
       ALLOCATE (x(n), xguess(n), xlb(n), xub(n))
       xlb = -100
       xub = 100
       DO i = 1, n
          xguess(i) = 0.1*i
       END DO
       CALL nnlpf(fcn, m, me, ibtype, xlb, xub, x)
       CALL wrrrn('The solution is', x)
       DEALLOCATE (x, xguess, xlb, xub)
    END
    SUBROUTINE fcn(x, iact, result, ierr)
       USE sharedvars
       IMPLICIT NONE
       INTEGER iact, i
       REAL (kind(1E0)) x(n), & ! N is taken from SHAREDVARS
          result
       LOGICAL ierr
       SELECT CASE (iact)
       CASE (0)
          result = 0
          DO i = 1, n
             result = result + (x(i)+i-3)**2
          END DO
       CASE (1)
          result = x(1) - 2.0E0*x(2) + 1.0E0
       CASE (2)
          result = -(x(1)**2)/4.0E0 - x(2)**2 + 1.0E0
       END SELECT
       RETURN
    END
Compile and run it for various values on n, such as n = 2, n=3, n=4, etc.
Andrew_Smith
Valued Contributor I
If you contain the FCN routine inside your program it gives scope to program variables inside FCN and also provides an explicit interface to FNC so that its argument declarations can be checked against the requirements. Now we dont need the EXTERNAL statement. Note that you did not declare or set IBTYPE.
PROGRAM TEST
   use NNLPF_INT
   INTEGER IBTYPE, M, ME
   M=1
   ME=1
   XLB = -HUGE(X(1))
   XUB = HUGE(X(1))
   !DO i =1,size(X)
   !END DO
CONTAINS
   SUBROUTINE FCN1(X, IACT, RESULT, IERR)
      INTEGER, intent(in) :: IACT
      REAL(KIND(1E0)), INTENT(IN) :: X(*)
      REAL(KIND(1E0)), INTENT(OUT) :: RESULT
      LOGICAL, INTENT(OUT) :: IERR
      WRITE(*), XLB ! Check we can see variables in scope of our container
      SELECT CASE (IACT)
      CASE(0)
      CASE(1)
      !CASE(2)
      END SELECT
   END SUBROUTINE
END PROGRAM
mecej4
It is declared and initialized to zero in the module.
And that is the problem with overuse of modules -- one tends to forget all the stuff put into the module, and it is ever so convenient to say "USE ...." when we no longer remember all the things that are now available. Thank goodness for "USE mymod, only: fork" and "USE mymod, except=>kitchen_sink".
huang_l_
    MODULE sharedvars
       IMPLICIT NONE
    END
    PROGRAM xnnlpf
       USE nnlpf_int
       USE wrrrn_int
       USE sharedvars
       IMPLICIT NONE
       REAL fvalue
       INTEGER i
       EXTERNAL fcn
       READ (*, *) n
       xlb = -100
       xub = 100
       DO i = 1, n
          xguess(i) = 0.1*i
       END DO
    END
       USE sharedvars
       IMPLICIT NONE
       INTEGER iact, i
          result
       LOGICAL ierr
       SELECT CASE (iact)
       CASE (0)
          result = 0
          DO i = 1, n
          END DO
       CASE (1)
       CASE (2)
       END SELECT
       RETURN
    END
tc.
okay,I have passed the optimization parameter to my FCN as you do . but i have another question here: if i have hundreds of constraints ,for example,500 equalities constraints and 500 unequalities ,with more than 5000 variables,how can i write the FCN? i don't think the "SELECT CASE" structure is a feasible way to do this. so i try the program using the "IF -ELSEIF -END IF" statements like below:
!  shuc.f90
!  FUNCTIONS:
!  shuc - Entry point of console application.
!  PROGRAM: shuc
!  PURPOSE:  Entry point for the console application.
MODULE my_data_type!自定义数据类型,包括机组数据,负荷数据
  TYPE:: unit_data
      CHARACTER (len=8) :: unit_name
      CHARACTER (len=4) :: unit_zone
      REAL :: zone_trans_pmax
      REAL::unit_pmax,unit_pmin
      CHARACTER (len=1) :: unit_type
      TYPE(unit_data),POINTER::next_unit_data
  END TYPE
  TYPE:: load_data
      CHARACTER (len=4) :: load_zone
      REAL :: peak_load,valley_load,zone_trans_pmax
      TYPE(load_data),POINTER::next_load_data
  END TYPE
  TYPE:: variable
      REAL::x
      TYPE(variable),POINTER::next_variable
  END TYPE
  CONTAINS
  SUBROUTINE unit_data_add(pos,head,unit_name,unit_zone,zone_trans_pmax,unit_pmax, unit_pmin,unit_type,unit_data_num)
      INTEGER::unit_data_num
      REAL ::zone_trans_pmax
      TYPE(unit_data),POINTER::temp,pos,head
      ALLOCATE(temp)
      temp%unit_name=unit_name
      temp%unit_zone=unit_zone
      temp%zone_trans_pmax=zone_trans_pmax
      temp%unit_pmax=unit_pmax
      temp%unit_pmin=unit_pmin
      temp%unit_type=unit_type
      NULLIFY(temp%next_unit_data)
      IF (.NOT.ASSOCIATED(POS))THEN
        ALLOCATE(pos)
        pos%unit_name=unit_name
        pos%unit_zone=unit_zone
        pos%zone_trans_pmax=zone_trans_pmax
        pos%unit_pmax=unit_pmax
        pos%unit_pmin=unit_pmin
        pos%unit_type=unit_type
        head=>pos
        NULLIFY(pos%next_unit_data)
      ELSE
        pos%next_unit_data=>temp
        pos=>temp
        IF( unit_data_num==1) THEN
          head%next_unit_data=>pos
        END IF
      END IF
!      DEALLOCATE( temp)
      unit_data_num=unit_data_num+1
  END  SUBROUTINE unit_data_add
  SUBROUTINE load_data_add(pos,head,load_zone,peak_load,valley_load,zone_trans_pmax,load_data_num)
      INTEGER::load_data_num
      REAL::peak_load,valley_load
      TYPE(load_data),POINTER::temp,pos,head
      ALLOCATE(temp)
      temp%load_zone=load_zone
      temp%peak_load=peak_load
      temp%valley_load=valley_load
      NULLIFY(temp%next_load_data)
        ALLOCATE(pos)
        pos%load_zone=load_zone
        pos%peak_load=peak_load
        pos%valley_load=valley_load
        head=>pos
        NULLIFY(pos%next_load_data)
      ELSE
        pos%next_load_data=>temp
        pos=>temp
        IF( load_data_num==1) THEN
          head%next_load_data=>pos
        END IF
      END IF
!      DEALLOCATE( temp)
      load_data_num=load_data_num+1
  END  SUBROUTINE load_data_add
    SUBROUTINE variable_add(pos,head,variable_num)
      INTEGER::variable_num
      TYPE(variable),POINTER::temp,pos,head
      ALLOCATE(temp)
      temp%x=1.
      NULLIFY(temp%next_variable)
        ALLOCATE(pos)
        pos%x=1.
        head=>pos
        NULLIFY(pos%next_variable)
      ELSE
        pos%next_variable=>temp
        pos=>temp
        IF( variable_num==1) THEN
          head%next_variable=>pos
        END IF
      END IF
!      DEALLOCATE( temp)
      variable_num=variable_num+1
  END  SUBROUTINE variable_add
END MODULE
MODULE  read_data
USE my_data_type
CONTAINS
SUBROUTINE read_optimization_para(peak_dc,valley_dc,peak_ac,valley_ac,head_unit,unit_data_num,head_load,load_data_num)
    REAL::peak_dc,valley_dc,peak_ac,valley_ac
    INTEGER::i,j
    CHARACTER(len=1000)::data_str
    TYPE(unit_data),POINTER::head_unit,tail_unit,ptr_unit
    TYPE(unit_data)::current_unit
    LOGICAL::DATA_READING=.FALSE.
    INTEGER::result_string_scan=0
    REAL::peak_load,valley_load,peak_total_load,valley_total_load
    TYPE(load_data),POINTER::head_load,tail_load,ptr_load
    INTEGER::size_of_variable
    NULLIFY(tail_load)
    NULLIFY(head_load)
    NULLIFY(head_unit)
    NULLIFY(tail_unit)
    !NULLIFY(head_variable)
    !NULLIFY(tail_variable)
    OPEN(UNIT=20,FILE='上海机组小开机.txt',ACTION='READ')
    load_data_num=0
    unit_data_num=0
    DO !读入机组数据
        READ(20,'(A)') data_str
        result_string_scan=INDEX(data_str,'end_of_unit_data')
        IF (result_string_scan/=0)THEN
            EXIT
        END IF
        IF(data_str(1:1)=='.')THEN
            CYCLE
        ELSE
            IF (DATA_READING==.TRUE.)THEN
                READ(data_str,*)unit_name,unit_zone,zone_trans_pmax,unit_pmax,unit_pmin,unit_type
                CALL unit_data_add(tail_unit,head_unit,unit_name,unit_zone,zone_trans_pmax,unit_pmax, unit_pmin,unit_type,unit_data_num)
            ELSE
                result_string_scan=INDEX(data_str,'begin_unit_data')
                    DATA_READING=.TRUE.
                END IF
                !result_string_scan=INDEX(data_str,'end_of_unit_data')
                !IF (result_string_scan/=0)THEN
                !    DATA_READING=.FALSE.
                !    EXIT
                !END IF
            END IF
        END IF
    END DO
    peak_total_load=0
    DO !读入分区负荷数据
        result_string_scan=INDEX(data_str,'end_of_load_data')
            EXIT
        END IF
            CYCLE
        ELSE
                READ(data_str,*)load_zone,peak_load,valley_load,zone_trans_pmax
                CALL load_data_add(tail_load,head_load,load_zone,peak_load,valley_load,zone_trans_pmax,load_data_num)
                peak_total_load=peak_total_load+peak_load
            ELSE
                result_string_scan=INDEX(data_str,'begin_load_data')
                    DATA_READING=.TRUE.
                END IF
                !result_string_scan=INDEX(data_str,'end_of_load_data')
                !    EXIT
                !END IF
            END IF
        END IF
    END DO
    DO !读入高峰低谷区外来电数据
        result_string_scan=INDEX(data_str,'end_of_power_injection_data')
            EXIT
        END IF
            CYCLE
        ELSE
                READ(data_str,*)peak_dc,valley_dc,peak_ac,valley_ac
            ELSE
                result_string_scan=INDEX(data_str,'begin_power_injection_data')
                    DATA_READING=.TRUE.
                END IF
                !    EXIT
                !END IF
            END IF
        END IF
    END DO
    CLOSE(20)
END SUBROUTINE read_optimization_para
END MODULE
    program shuc
    include 'link_fnl_shared.h'
    include 'link_fnl_static.h'
    use lin_eig_self_int
    use lin_sol_svd_int
    USE WRRRN_INT
    USE NNLPF_INT
    USE my_data_type
    USE READ_DATA
    IMPLICIT NONE
    INTEGER::IBTYPE=0
    INTEGER::M, ME
    !REAL :: zone_trans_pmax
    !REAL::unit_pmax,unit_pmin
    !CHARACTER (len=1) :: unit_type
    INTEGER::variable_num=0
    REAL::k=1
    REAL::peak_dc,valley_dc,peak_ac,valley_ac!高峰低谷时段区外直流、交流来电
    INTEGER,PARAMETER::N=4
    !REAL::A(N,N)
    !REAL::D(N)
    INTEGER::i,j
    !CHARACTER(len=1000)::data_str
    TYPE(unit_data),POINTER::head_unit,ptr_unit
    !TYPE(unit_data)::current_unit
    !LOGICAL::DATA_READING=.FALSE.
    !INTEGER::result_string_scan=0
    !CHARACTER (len=4) :: load_zone
    !REAL::peak_load,valley_load,peak_total_load,valley_total_load
    TYPE(load_data),POINTER::head_load,ptr_load
    !TYPE(variable),POINTER::head_variable,tail_variable
    REAL(KIND(1E0)) FVALUE, X(300), XGUESS(300), XLB(300), XUB(300)
    EXTERNAL FCN
    NULLIFY(ptr_load)
    NULLIFY(ptr_unit)
    CALL read_optimization_para(peak_dc,valley_dc,peak_ac,valley_ac,head_unit,unit_data_num,head_load,load_data_num)
    !ME=2!等式约束两个,分别为整数约束和高峰电力平衡约束
    !M=2*load_data_num+ME!总约束为:分区数*2(高峰、低谷分区主变不过载)+ME
    !!定义变量列表
    !DO i =1,3*unit_data_num
    !   CALL variable_add(tail_variable,head_variable,variable_num)
    !END DO
    !size_of_variable=3*unit_data_num
    M=2
    ME=1
    ptr_unit=>head_unit
    DO i=1,unit_data_num
        XLB(i)=ptr_unit%unit_pmin
        XUB(i)=ptr_unit%unit_pmax
        ptr_unit=>ptr_unit%next_unit_data
        XGUESS(i)=1
        XGUESS(i+unit_data_num)=XUB(i)!迭代初始方式为高峰、低谷全开机满发
        XGUESS(i+2*unit_data_num)=XUB(i)
    END DO
    NULLIFY(ptr_unit)
    !XLB = -HUGE(X(1))
    !XUB = HUGE(X(1))
    CALL NNLPF (FCN, M, ME, IBTYPE, XLB, XUB, X,IPRINT=1)
    !DO i =1,size(X)
    !END DO
    pause
    end program shuc
SUBROUTINE FCN (X, IACT, RESULT, IERR)
USE READ_DATA
USE my_data_type
INTEGER IACT
LOGICAL IERR
INTEGER::i,j
INTEGER::unit_data_num=0
INTEGER::load_data_num=0
REAL::peak_total_load,valley_total_load
NULLIFY(ptr_load)
NULLIFY(ptr_unit)
peak_total_load=0
valley_total_load=0
ptr_load=>head_load
DO i =1,load_data_num
    peak_total_load=peak_total_load+ptr_load%peak_load
    valley_total_load=valley_total_load+ptr_load%valley_load
    ptr_load=>ptr_load%next_load_data
END DO
variable_num=3*unit_data_num
WRITE(*,*) peak_total_load,peak_ac,peak_dc
IF(IACT==0)THEN!目标函数,低谷本地调峰缺口最小
    RESULT=0
        RESULT =RESULT+ X(i)*X(i+unit_data_num*2)
    END DO
    RESULT=RESULT-valley_total_load-valley_ac-valley_dc
ELSEIF(IACT==1)THEN!高峰电力平衡约束
    RESULT=0
        RESULT =RESULT+ X(i)*X(i+unit_data_num)
    END DO
    RESULT=RESULT-peak_total_load-peak_ac-peak_dc
ELSEIF(IACT==2)THEN!机组开机状态0-1约束
    RESULT=0
        RESULT=RESULT+X(i)**2*(1-X(i))**2
    END DO
ELSEIF(IACT<=3+load_data_num)THEN !高峰主变过载约束
    IF (IACT==3)THEN
        ptr_load=>head_load
    END IF
    RESULT=ptr_load%zone_trans_pmax-ptr_load%peak_load
    ptr_unit=>head_unit
    DO i =1,unit_data_num
        IF (ptr_unit%unit_zone==ptr_load%load_zone)THEN
            RESULT=RESULT+X(i+unit_data_num)*X(i)
        END IF
    END DO
ELSEIF(IACT<=3+2*load_data_num)THEN !低谷主变过载约束
    IF (IACT==3)THEN
        ptr_load=>head_load
    END IF
    RESULT=ptr_load%zone_trans_pmax-ptr_load%valley_load
    ptr_unit=>head_unit
            RESULT=RESULT+X(i+2*unit_data_num)*X(i)
        END IF
    END DO
END IF
RETURN
END
i don't know if it will work,and there are so many "can't find or open PDB files" when linking ,and the .exe just exit without any results,shown in the following picture.
could you help me again?  thanks very much!!
Ignore the "can't find or open PDB file" messages when you start debugging (not linking). They are not important. I also suggest that if you want to include longer sources, please attach them as .f90 files rather than inserting into the post.
mecej4
Your code compiles and links with no errors, but to run it the data file is needed.
Whether you use SELECT constructs or not is up to you. If you can group your constraints into, say, three blocks, with all the constraints in each block being of similar form, you could do something similar to
   if (iact.gt.0.and.iact.le.500) then
else if(iact .lt. 1000) then
   result = x(iact) - x(iact+400)
else
endif
huang_l_
else
endif
i have uploaded my .f90 files and the .txt input files needed to run the program in the attachments.
but it can't get any result in the output  cmd window.
i also try the "CALL NNLPF (FCN, M, ME, IBTYPE, XLB, XUB, X,XGUESS,IPRINT=1)" , where i offered my XGUESS as an initial guess of the solution, which i think is helpful to get the right answer,but i get an err as following:
error #6285: There is no matching specific subroutine for this generic subroutine call.   [NNLPF]
can you help me? thanks a lot!
mecej4
There are several errors in your program. You have declared several arrays that should be of size N (= the number of variables in the optimization problem) with dimension (300). The IMSL optimization routine obtains N from the size of the array passed to it, so it thinks that N = 300, whereas you want N = 21.
The input bounds must satisfy xlb < xub. You have several variables for which the bounds given satisfy xlb = xub. Do you want those elements of x() to be fixed at the bound values? If so, reformulate the problem by separating variable variables and fixed "variables".
To pass an optional argument in Fortran 90, you have to follow certain rules. To pass XGUESS, you need to write ",XGUESS=XGUESS", using the keyword name.
You should not use the == or .EQ. operators to compare logical expressions. Use .EQV. instead.
Your FCN subroutine is rather long and complicated. Have you checked whether all the components of the objective and constraints are calculated correctly? If not, I suggest that you replace the call to NNLPF with several calls  "CALL FCN(xguess,Iact,fvalue,ierr)" with different values of Iact, remove all references to IMSL, and run with runtime checks turned on for uninitialized variables, array bound errors and so forth. I have a suspicion that your linked list of pointers is such that some uninitialized pointers are being dereferenced.
The routine also calls "read_optimization_para" at its beginning, which means that the data file gets read and data structures get initialized hundreds of times. Is this really necessary?
huang_l_
i have modified my codes and it can run to an result now,even though the result is not what i think is correct. i guess the possible reason is that the NNLPF routine is not desighed to find global solution.
actually, in my equality contraints below:
ELSEIF(IACT==2)THEN!the 0-1constraints
    RESULT=0
        RESULT=RESULT+X(i)**2*(1-X(i))**2*9999
    END DO
i just want my X(1,len(X)/3)={0,1}, that is binaray numbers. but i can't find the routine that can solve optimization problem containing binaray  variables in the help document. so can you tell me which routine to use to solve this problem?
thanks very much!
huang_l_
supplimentary comments: my equality and unequlity constraints consists of Xi*Xi+unit_num items,where Xi  (i>=1 and i<=unit_num )are binary variables(0-1) and Xi+unit_num items(unit_num  is a constant) are real numbers. jusu like the following constraints :
 X1*X1+unit_num + X2*X2+unit_num +.....+ Xunit_num *Xunit_num +unit_num =constant1
 X1*X1+unit_num + X2*X2+unit_num >=constant2
 X3*X3+unit_num + X4*X4+unit_num +X5*X5+unit_num >=>=constant3
X6*X6+unit_num + X7*X7+unit_num +X8*X8+unit_num +X9*X9+unit_num +X10*X10+unit_num >=constant4
is there any routine to solve this problem in the IMSL package?
thanks!
mecej4
If you want to do pseudo-boolean variable optimization and/or global optimization, you will have to look elsewhere for suitable algorithms. Consult Prof. Mittelmann's site at http://plato.asu.edu/guide.html .
huang_l_
thanks very much!
huang_l_
    RESULT=0
    END DO
thanks very much!
i have another question here that why the indicated result after iteration doesn't meet the 1st equality constraints as shown below?
    RESULT=0
        local_p_peak =local_p_peak+ X(i)*X(i+unit_data_num)
    END DO
    RESULT=RESULT-peak_total_load+peak_ac+peak_dc
thank you again!
mecej4
The IMSL routine gave up on the calculation and returned without any iterations. In fact, it did not even evaluate the object function once before giving up. See this part of the output:
TERMINATION REASON:
STEPSIZESELECTION: NO ACCEPTABLE STEPSIZE IN [SIGSM,SIGLA]
EVALUATIONS OF F                            0
EVALUATIONS OF GRAD F                       0
EVALUATIONS OF CONSTRAINTS              16535
EVALUATIONS OF GRADS OF CONSTRAINTS         0
I would not be brave enough to try such a large problem without having good starting data. You have set the bounds as (-1,2) for many variables, and the starting value as 1. Are these reasonable? Can you do better? I am not going to be of much help in this part because I have no knowledge of the application area. Do the variables have units (metres, pascals, volts, etc.)?
mecej4
Do you have a version of the problem with fewer variables and constraints? If so, you may be able to solve that problem first, and use the results from it to generate good starting values for the larger problem.
After thinking and looking at your problem over a few hours, I think that I have found a way to solve it. Here are my thoughts.
You have N = 3 n variables, where n is what you call unit_data_num in the program.Let the unknowns be called X = {u, v, w} where u = X(1:n), v = X(n+1:2n), w = X(2n+1:N). Then, your objective function is
     F = uTw + a
and the general constraints are of the form
   some(u.*v) >= b,     some other(u.*w) >= c
In order to force u to be an array of binary variables you have added the artificial constraint
     norm {u.*(1 - u)} = 0
The binary variables are not only going to cause standard continuous optimization methods to have a lot of trouble, but they are also unnecessary!
Use new variables {y, z}, where y = u.*v and z = u.*w, where ".*" stands for element-by-element multiplication, as in Matlab. With these variables, you no longer need the additional constraint, and you have a third fewer variables. The problem that you have implemented in the program may now be recast as a linear programming (LP) problem involving continuous variables only, and could be solved efficiently using an LP solver.
I have attached a file containing the solution that I found (using a modified version of your program, which I have attached also). In the solution file, if a line in the file ends with an 'l', that variable is at the lower bound; if a 'u', it is at the upper bound. Otherwise, the variable is free (bounds not active). You may interpret those variables that are zero to be entities such as "power plant P is on but its output is 0 or power plant P is off but if it had been on then the output would have been 200 MW but not delivered to consumer/customer Q".
