29430 Discussions
Q about careless passing of optional arguments to furhter calls
Witold_I_
Hello, Yet another problem: I have a 3rd party code in which there is a "chain" of optional argument passing done without checking with 'present'. It looks like tnis (example, I/O is done to use unpredictable data, to avoid compiler optimizations): module m0016 contains subroutine f(j) implicit none integer,intent(in),optional::j integer i write(*,*)'f(): enter i:' read(*,*)i call g(i,j) return end subroutine f subroutine g(i,j) implicit none integer,intent(in)::i integer,intent(in),optional::j write(*,*)'g(): i=',i if(present(j)) write(*,*)'g(): j=',j return end subroutine g end module m0016 program test use m0016 implicit none integer::j call f() write(*,*)'main: enter j:' read(*,*)j call f(j) stop end program test This code compiles and surprisingly works... However use of j in f() in call to g() without 'present' looks strange... Is such a careless use of optional arguments correct and allowed by Fortran standards?
Yes, this is allowed. The present-status of optional arguments is carried through. I am not sure why you call this "careless", it can be a very useful property. It does require that an explicit interface be visible at all steps.
Witold_I_
Compiler doc (on kwrd OPTIONAL) doesn't clarify this question and examples attached also do not cover the matter (<- but please don't read this as a complaint). That's why I decided to ask this Q. And yes, I admit: this property is useful - it decreases amount of code, delegating the task to compiler or some additional runtime code (?) generated implicitly.
See the additional topic "Optional Arguments" that is referenced at the bottom of the OPTIONAL page. The description of OPTIONAL is about the syntax term - the concept of omitted arguments is more complex and discussed elsewhere. I'll also comment that the compiler reference is not intended as a tutorial on the language.
