Q about variables in Contained routines
William_S_1
Suppose I have:
SUBROUTINE SUB1
integer ix,iy,iz
contains
subroutine sub1a
integer iz
print *,ix,iy,iz
end subroutine
end
Now notice I have iz declared twice. Would that be local to the contained routine?
I assume that the contained routine can reference ix, and iy.
Incidentally, one debugging headache is that if I am within
the contained routine, at a breakpoint, I cannot reference
any variables that are not declared INSIDE that routine.
So even though the routine can reference those variables, the DEBUGGER can NOT get their values.
Is there a way around that?
so far I have to insert P
William_S_1
To reference those variables with the debugger, I have to insert
print statements, which defeats the purpose of having it there.
Variables in the calling sequence CAN be referenced, though
as well as local variables.
Steven_L_Intel1
The iz you declare inside sub1a is local to the routine - ix and iy are "host associated". To see the variables in the host, use the "Stack Frame" pulldown to change the current frame to that of the outer routine.
