29389 Discussions
Q about variables in Contained routines
William_S_1
Suppose I have:
SUBROUTINE SUB1
integer ix,iy,iz
contains
subroutine sub1a
integer iz
print *,ix,iy,iz
end subroutine
end
Now notice I have iz declared twice. Would that be local to the contained routine?
I assume that the contained routine can reference ix, and iy.
Incidentally, one debugging headache is that if I am within
the contained routine, at a breakpoint, I cannot reference
any variables that are not declared INSIDE that routine.
So even though the routine can reference those variables, the DEBUGGER can NOT get their values.
Is there a way around that?
so far I have to insert P
William_S_1
To reference those variables with the debugger, I have to insert
print statements, which defeats the purpose of having it there.
Variables in the calling sequence CAN be referenced, though
as well as local variables.
The iz you declare inside sub1a is local to the routine - ix and iy are "host associated". To see the variables in the host, use the "Stack Frame" pulldown to change the current frame to that of the outer routine.
