29618 Discussions
/Qparallel or -parallel flag compined with Coarray / MPI
DataScientist
Valued Contributor I
My understanding is that the /Qparallel or -parallel flags work as OpenMP parallelization underneath. But what does happen if a Coarray or MPI parallelized code is combined and compiled with the -parallel flag? I do not see errors or problems happening on a test problem that I have tried, but I doubt if it has led to any performance improvements beyond what Coarray/MPI offers.
On a side note, does the Intel ifort automatically integrate the omp dynamic library with the final executable or the DLL library? or should it be separately provided along with the executable? I am getting mixed results on a test system, once it work, another time (combined with Coarray/MPI) the executable complained about missing `libiomp5md.dll`.
Steve_Lionel
Auto-parallel will try to parallelize loops that operate on local variables. You're right that it uses OpenMP underneath. There's nothing inherently problematic about combining coarrays and OpenMP and I have seen it done a number of times.
On Windows, the OpenMP library is provided in DLL form only, so you will always need to have libiomp5md.dll in PATH (or in the executable directory). On Linux, a static library is still available, though discouraged.
As always, you should test the performance with different options to see which works best for you.
Steve_Lionel
JohnNichols
Honored Contributor I
Is it better to have it in the path or in the exe directory -- I would have thought the former from previous comments you made?
Steve_Lionel
Better in PATH - as the installer makes it. But some people want to copy their EXEs and not install the "redistributables", so putting copies of the DLLs in the EXE folder is an alternative.
