Qs about Pointer use
gelarimer
INTEGER(1) , ALLOCATABLE, TARGET:: Buf(:)
TYPE(T_PRINTER_INFO_2) PI2
POINTER(pPI2, PI2)
ALLOCATE(Buf(iBytesNeeded), STAT = iErr)
! Buf() will be filled inwith PRINTER_INFO_2 structure
! by win32 fn. GetPrinter()
pPI2 = LOC(Buf)
DEALLOCATE(Buf, STAT = iErr)
Questions
1) Pointersand Targets should be the same type, but Buf is type Integer and pPI2points to a Derived Data type, is this a potential problem in theabove code?
2) does Buf() need the Target attribute?
3)would INTEGER(4) for Buf()be better for the Compiler?
(Can always calculatethe correct number of dbl words to Allocate)
4) OR would it be more appropriate, here,to use the intrinsic function MALLOC() to achieve the same results?
Thanks for any information.
You should use malloc for this - ALLOCATABLE allows the compiler to make some assuimptions that your program might violate. Typically, PI2 would be declared as type T_PRINTER_INFO, or whatever... Try not to "fool" the compiler if you don't have to.
gelarimer
Thanks Steve, appreciate the information.
