/Qsave and automatic arrays
Aaron_S_1
My understanding is that /Qsave will place almost all variables into static allocation. I have also read that arrays declared as:
Subroutine Example(A,n)
    Integer :: n
    Integer :: A(n)
    The rest of the program...
End Subroutine
Are allocated on the stack unless /heap-arrays is specified. Where are arrays of these type (automatic arrays?) allocated with the /Qsave switch? I appreciate any insight anyone might be able to offer. Thanks.
Your example is what is called an "adjustable array" - a dummy argument whose bounds are taken from another dummy argument (or a COMMON or module variable.) Its allocation comes from the caller.
Now if you had left A out of the argument list, then you'd indeed have an automatic array. /Qsave has no effect on these. An automatic array is stack allocated unless /heap-arrays is in effect.
/Qsave applies to local variables that are not automatic. It is the equivalent of adding SAVE for every non-automatic variable in the routine. One unfortunate side effect is that it also makes any ALLOCATABLE variables SAVEd, which may not be what you want.
