/heap-arrays Memory Leak
Aaron_S_1
I've run into a stack overflow error when passing some large data arrays. I was exploring possible solutions to the problem when I came across this page: https://software.intel.com/en-us/articles/intel-fortran-compiler-increased-stack-usage-of-80-or-higher-compilers-causes-segmentation-fault which states that the /heap-array option could be used, but "Note the 13.0 initial release of the compiler has a memory leak with the  -heap-arrays switch, so do not use it with this release." Does this mean that all 13.0 releases will create a memory leak with the /heap-array switch? And 13.1 version numbers are the first that won't? We are using XE 2013 Update 3, or 13.0.3624.2010. Thanks in advance for any help.
That problem was fixed in 13.0.1 (Composer XE 2013 Update 1). I've updated the article to add that information.
