29276 Discussions
/Qsox option to save compiler options and version info
vivekrao4
If I compile a program with the /Qsox option, how can I extract the compiler options and version info from the executable? Thanks.
From the executable? Notepad or some utility that searches for strings. Also, if you are using VS2005, then the string won't be there. You can get it from the object with "dumpbin -directives".
carlls
I know the keyword here is executable, but what if I want to have the data tucked into the obj? As in a string that might look like:
ifort Version 9.1 Build 20060925, ifort flags -Qzero -Od -Qopenmp -Z7 -MD -RTCu -Qsox -check:all
I guess I could use /bintext? ... is that the right thing to do?
/Qsox does place the string in the .obj.
[cpp]F:MyProjects>ifort /c /Qsox end.f90
Intel Visual Fortran Compiler Professional for applications running on IA-32,
 Version 11.0    Build 20081105 Package ID: w_cprof_p_11.0.066
Copyright (C) 1985-2008 Intel Corporation.  All rights reserved.
F:MyProjects>dumpbin -directives end.obj
Microsoft  COFF/PE Dumper Version 9.00.21022.08
Copyright (C) Microsoft Corporation.  All rights reserved.
Dump of file end.obj
File Type: COFF OBJECT
   Linker Directives
   -?comment:"Intel
   Fortran
   Compiler
   Professional
   for
   applications
   running
   on
   IA-32,
   Version
   11.0
   Build
   20081105
   %s
   end.f90
   -c
   -Qsox"
   -?comment:"Intel
   Fortran
   Compiler
   Professional
   for
   applications
   running
   on
   IA-32,
   Version
   11.0
   Build
   20081105
   %s
   end.f90
   -c
   -Qsox"
   -defaultlib:"ifconsol"
   -defaultlib:"libifcoremt"
   -defaultlib:"libifport"
   -defaultlib:"libmmt"
   -defaultlib:"LIBCMT"
   -defaultlib:"libirc"
   -defaultlib:"svml_disp"
   -defaultlib:"OLDNAMES"[/cpp]
