29386 Discussions
Question about OpenMP attribute of index variables.
amat000
I have a question about OpenMP attribute of index variables in a Region but not in constant.
The specification of OpenMP3.0 said,
2.9.1.2 Data-sharing Attribute Rules for Variables Referenced in a
Region but not in a Construct
Fortran
implied-do indices, forall indices, and other local variables declared in called
routines in the region are private.
I believe index i in the comp subroutine as follows should be private,  but it is shared.
       program test
       parameter (N=400)
       common/tmp/i,j,k
       real a(N,N),b(N,N),c(N,N)
!$omp parallel do
       do j=1,N
       do i=1,N
         a(i,j)=real(i)
         b(i,j)=real(i+j)
         c(i,j)=0.0
       enddo
       enddo
!$omp parallel do
       do j=1,N
       do k=1,N
          call comp(a,b,c,N)
       enddo
       enddo
       write(*,*) c(N,N)
       stop
       end
       subroutine comp(a,b,c,N)
       common/tmp/i,j,k
       integer omp_get_thread_num
       do i=1,N
         write(omp_get_thread_num()+200,*) i
         c(i,j)=c(i,j)+a(i,k)*b(k,j)
       enddo
       return
       end
After this program was launched with 32 threads, I checked the head of fort.2?? files.
==> fort.223 <==
           1
         222
         223
         224
         225
The correct values are
           1
           2
           3
           4
           5
compiler version : Intel 64 13.0 Build 20120731
processors       : E7-8837@2.67GHz
OS               : SLES 11SP1
Could you check out this issue, please?
Best rergards,
Akiko MATSUMOTO
