Question about reading data
Zhanghong_T_
I am trying to read a text file with the following data:
1 25 2 24 3 23 4 22 7 19 10 16 13
5 6
21 20
8 9
18 17
11 12
15 14
I defined an array:
integer list(7,25)
and then initialized it to zero.
Now I wish the data be filled into the front ofevery line of thearray, how should I design the read program?
Zhanghong Tang
h-faber
Does your textfile always look like your example or do you have variable number of data?
Zhanghong_T_
Thank you for your reply. Just as you say, the number of data in every line is unknown, so...
Zhanghong_T_
When I using the read statement as follows,
read(1,*)data
it will always turn to the next line, can I read several number in a line with several read statement? Just as
read(1,*)(data(i),i=1,n)
But I don't know the value of n, how should I do?
Zhanghong Tang
anthonyrichards
New Contributor III
1) Read each record as a character string
CHARACTER(500)
READ(1,*) STRING
2)Get the string's length
LENGTH=LEN_TRIM(STRING)
2) count the spaces in the string: this is one less than the number of integer data items
ISTART=1
DO J=1,25
ISPACE=INDEX( STRING(ISTART:LENGTH), ' ')
IF(ISPACE.EQ.0) EXIT
ISTART=ISPACE+1
ENDDO
3) Use in internal read, selecting to read in this number+1 items
READ(STRING(1:LENGTH),*) (DATA(I),I=1,NUMBER)
anthonyrichards
New Contributor III
The following code assumes that ther will be at elast one number in a record.
CHARACTER(500)
INTEGER(4) I, NUMBER, ISTART, ISPACE
READ(1,*) STRING
ISTART=1
NUMBER=0
DO J=1,25'
! EXIT IF SPACE NOT FOUND FROM 'ISTART' TO THE END
ISTART=ISPACE+1
NUMBER=NUMBER+1
ENDDO
NUMBER=NUMBER+1
I have not tested it, but it can be made to work.
Zhanghong_T_
Thank you very much! Now I got it.
Zhanghong Tang
anthonyrichards
New Contributor III
I forgot to include a line of code
STRING = ADJUSTL(ADJUSTR(" "))
(or similar) to initialise the STRING variable to all blanks BEFORE each READ, otherwise it will contain stuff from a previous READ which will screw things up eventually, if the next record is shorter than the last.
Les_Neilson
Valued Contributor II
Even simpler STRING = " " will do
Les
