Question about substrings
Intel_C_Intel
The documentations states that for a character string of the form
v(e1:e2)
"Both e1 and e2 must be within the range 1,2, ..., len, where len is the length of the parent character string. If e1 exceeds e2, the substring has length zero.
So is it safe to have a substring of length 0? I.e., I have code like:
l=len_trim(string) !where string is all blank
call sub(string(1:L))
where sub is like
subroutine sub(string)
character string*(*)
if (len_trim(string) .gt.0) then
do stuff
endif
end
It works, but can it lead to trouble? Do I have to check for this?
Intel_C_Intel
I have no idea how this got in here 3 times.. Sorry.
Jugoslav_Dujic
Valued Contributor II
It's [supposed to be *] safe. Of course, you can't do much with such a string, but LEN and LEN_TRIM will return 0 and assignment will be a no-op. I don't have Standard handy, but I suppose you shouldn't try internal WRITE on it.
Jugoslav
*) However, the feature in question looks like a fertile ground for compiler bugs -- I'm not saying there is an actual one in CVF or IVF, just that it looks obscure enough that it can be a good candidate for overlooking.
Jugoslav_Dujic
P.S. You (only you and Steve as administrator) can go back to extra posts and delete them while logged in.
I'm not sure users can delete their own posts. I'll take care of it.
This is legal in Fortran 90. If the end position is less than the start position, the string has zero length. F77 did not allow for this, however, so old compilers may behave erratically with zero-length strings.
Jugoslav_Dujic
They can -- I did it myself several times before (when accidental multiposting occurred). I didn't test if it makes difference when the message is first in the thread.
Jugoslav
Intel_C_Intel
Thanks; it's a real convenience for me when intrepreting arbitrary (possibly long) format-free user input strings. I don't believe it worked this way in CVF.
I tried to find a way to delete the extras, but couldn't figure out how.
It worked in CVF, as far as I know.
Jugoslav_Dujic
[Doesn't really matter, but for information] "Delete message" option can be found under "Options" "menu" on the blue header of each message. It is active only if it is your message and you're logged in.
Jugoslav
Message Edited by JugoslavDujic on 06-18-2004 10:56 AM
Intel_C_Intel
Actually, it seems to appear under options only if it's yours AND you are still in the session that created it. Can't come back to it later....
Jugoslav_Dujic
Dunno -- I've just successfully edited myprevious message from this thread, couple of weeks old.
Jugoslav
Intel_C_Intel
I still can't do it.....
