If you specify intent(in), the Intel Fortran help file says the actual argument must be an expression. In this example where the argument is just a variable (but still a legal expession). Is the argument A evaluated as an expression and the result sent to foo to prevent modification by foo?
It seams superfluous to copy the argument when the compiler has already made sure we don't modify the dummy argument and it is illegal to attempt to do so. If A was a large data structure, making a copy would be a serious problem. Thus intent(in) would best be avoided where we are passing simple variables.
Andy
program test
use fooMod
implicit none
real A
a = 1.0
call foo(A)
end program
module fooMod
implicit none
contains
subroutine foo(B)
real, intent(in) :: B
end subroutine
end module
Andy
program test
use fooMod
implicit none
real A
a = 1.0
call foo(A)
end program
module fooMod
implicit none
contains
subroutine foo(B)
end subroutine
end module
Hmm. That "Any associated actual argument must be an expression" isn't correct. A variable is fine. INTENT(IN) says that the called procedure does not redefine or change the definition status of the argument. The compiler can use this information in optimization.
I will ask the writers to remove that text. Thanks for pointing it out.
