Question on warning LNK4098
rahzan
I am getting the following warning on linking a static library (which works well with console apps) into a (inprocess) com-dll.
warning LNK4098: defaultlib "libc.lib" conflicts with use of other libs; use /NODEFAULTLIB:library
I have asked this before and the answer has been that the run-time libraries used are not matching.
1. Where can I find these run-time libraries among the project settings?
2. What libraries should I use so that this library is not so darn picky about what type of application is calling it? Or is it not possible?
Thanks in adv.
Tim
rahzan
Use
/libdir:noauto
on the static library's project.
Steven_L_Intel1
You probably want to start with Do you Suffer from the Heartbreak of MCLS?
Steve
