QuickWin and Windows API
NotThatItMatters
I have created a Fortran app with QuickWin which makes use of a few user32 Windows API calls.  Why?  The app needs to build a dynamic menu structure where menu items come and go according to the whims of a governing input file.  The app also needs to properly post-process in case the user pushes the red X in the upper right-hand corner of the window.  Anyway, I had thought I would be able to handle these things strictly with QuickWin but have not been able.
The problem I am having with the app is that if any of the menus are active upon program termination, the application hangs as if in an infinite loop.  I am using a few calls to user32.  The final call is to the following skeletal routine which evidently does not work.
[fortran]
SUBROUTINE DESTROY_WINDOW()
INTEGER (KIND = 4) ITEMID
INTEGER (KIND = LRESULT) RESULT
ITEMID = SETACTIVEQQ(0_4)
WIN_HANDLE = GETHWNDQQ(QWIN$FRAMEWINDOW)
IF (WIN_HANDLE /= -1_HANDLE) THEN
IF (GETEXITQQ() == QWIN$EXITNOPERSIST) THEN
RESULT = SendMessage(WIN_HANDLE, WM_DESTROY, 0_fWPARAM, 0_fLPARAM)
END IF
END IF
END SUBROUTINE DESTROY_WINDOW
[/fortran]
jimdempseyatthecove
FWIW I use the following:
[fortran]
! some place in main thread, may occur periodically (as user has option to kill dialog without killing app)
if(.not. ControlPannelRunning) then
  ! before  creating the dialog box insert values that may be examined/modified
  ! by the dialog box
  vIntegrationStepsize = DLHOST
  ! Create seperate thread to run the Modal Dialog control pannel
  ControlPanelHandle = CreateThread(&
   & NULL, &
    & ControlPanelStack, &
    & loc(ControlPanel), &
    & loc(ControlPanelArg), &
    & ControlPanelFlags, &
    & loc(ControlPanelThread_ID))
  ! Check for CreateThread error here (if so inclined)
  ! Wait until flag set by control pannel thread
  ! indicates initialization complete
  do while(.not. ControlPannelRunning)
    milliseconds = 500
    call sleepqq(milliseconds)
  end do
  ! indicate for my thread that additional work needs to be done
  INIT_AVFRT_AllocateMemory = .false.
  AVFRT_Running = .true.
  ! My code has a Pause/Continue button, as well as
  ! if Pause was set as default startup, then wait for Continue or
  do while ((ControlPanelPause .eq. .true.) .and. (ControlPanelExit .eq. .false.))
    milliseconds = 500
    call    Update_AVFRT('INIT_AVFRT') ! while in Pause allow for manipulation of 3D graphics
  end do
endif
! end of code in main thread (or subroutine periodically called from main)
{seperate source}
integer(4) FUNCTION ControlPanel(arg)
!DEC$ ATTRIBUTES STDCALL, ALIAS:"_controlpanel" :: ControlPanel
    USE IFLOGM
    use   GlobalData
    implicit none
    INCLUDE 'RESOURCE.FD'
    integer(4),POINTER :: arg
    integer(4) returnVal, ns
    CHARACTER(256) text
    LOGICAL retlog
    external ControlPanelCallBack
    retlog = DLGINIT( IDD_DIALOG1, ControlPanelDlg )
    if(.not. retlog) write(*,*) "Dialog error for IDD_DIALOG1"
    call DlgSetTitle( ControlPanelDlg, ControlPanelTitle )
    ControlPannelRunning = .true.
    returnVal = DlgModal( ControlPanelDlg ) ! Doesn't return unless cancled (or IDC_event not specified)
    ControlPanelExit = .TRUE.
    ControlPanelPause = .FALSE.
    ControlPanel = returnVal
end FUNCTION ControlPanel
SUBROUTINE ControlPanelCallBack( dlg, id, callbacktype )
!DEC$ ATTRIBUTES DEFAULT :: ControlPanelCallBack
  USE IFLOGM
    use GlobalData
    implicit none
  TYPE (dialog) dlg
  INTEGER id, callbacktype, iStat
  CHARACTER(256), automatic :: text
  LOGICAL retlog
  INTEGER cel, far, retint
  real(8), automatic :: xyz(3)
  text = 'undefined'
  ControlPanelPauseRefresh = .true.
  NextDisplayTime = 0 ! update now
  SELECT CASE (id)
    CASE (IDC_RADIO1)
    ! Radio button 1 selected by user so
    ! change display accordingly
      vIavDisplayFrame = 0   ! vIavDisplayFrame = 0 Inertial Frame
      ! vIavDisplayFrame = 1 Orbital Frame
    CASE (IDC_RADIO2)
  END SELECT
END SUBROUTINE ControlPanelCallBack
[/fortran]
This uses a seperate thread running a Modal Dialog (not modeless).
Jim Dempseyt
jimdempseyatthecove
I should add. The main app is a console application (compute intensive parallel OpenMP), using a seperate thread to run a Modal Dialog Box. The application also uses "CALL avNewViewer(viewerID)" zero, one, or multiple times to create zero, one or more Intel Array Visualizer processes connected to the applicaiton. IOW I can have multiple display processes running concurrently with the computation process showing different aspects of the simulation. e.g. multiple 3D views from different perspectives, and/or 2D charts.
Jim Dempsey
andrew_4619
Steve Lionel (Intel) wrote:
Something has to handle the messages for the modeless window - perhaps QuickWin does that automatically.
Yes is must do that or more specifically windows will, the quickwin routines are afterall just a wrapper for standard windows api functionality.  You can capture the for the modeless dialog by having a callback subroutine to to dialog name itself which will be called with the callback type set to DLG_DESTROY when the x is hit or DLG_INIT when the doalog it is first displayed after dlgmodeless is called.
I normal check something like:
if(mydlg%DLGID.ne.0 .and. mydlg%HWND.ne.0 ) return ! dlg is already initialised AND active
before calling dlgmodeless so I don't end up with 2 instances on the screen
andrew_4619
why do my posts disappear and then appear an hour or three later? No message about being 'moderated' was given?
dboggs
Well I stand corrected--I guess. I'm sure the older documentation I was familiar with stated that modeless dialog boxes could not be used with Quickwin, but the current documentation only IMPLIES that it cannot. Or at least that is what I infer. It says that modeless boxes are "typically used in a Windows application" while "modal boxes can be used in any application," and when you look up DLGMODELESS in the A-Z reference, under Compatibility, it lists "Windows Console DLL Lib" but Quickwin is conspiculously absent.
But if it works, it works.
NotThatItMatters
This is a little something along the lines of "and now, for something completely different..."  I have been reading Using Intel Visual Fortran to Create and Build Windows-Based Applications and have noted most dialog-based code has the following stuff at the top of the code:
[fortran]USE IFLOGM
IMPLICIT NONE
INCLUDE 'RESOURCE.FD'[/fortran]
My project for not quite obvious reasons has a "resource.h" file which looks like a C include file.  It also includes a version.h file for executable versioning.  I am noting the symbols I need are within this file but apparently not readily available to the Fortran code.  Any hints as to how I might get these symbols or perhaps reconfigure the code?
andrew_4619
There is a tool deftofd to convert, it can be run from in VS but I use from a script..
"C:\Program Files (x86)\Intel\Composer XE 2011 SP1\bin\ia32\deftofd.exe" resource.h >resource.fd
There's instructions for setting up deftofd in Using Intel®Visual Fortran to Create andBuild Windows*-Based Applications - search for deftofd.
NotThatItMatters
Now that this small problem is settled, I am having another small problem that I cannot resolve.  The compiler is complaining:
error #6423: This name has already been used as an external function name.
Most compiler errors are self-explanatory.  This one has me stumped.  Any ideas?
andrew_4619
what is the name it objects to? The is something that is  declared twice.
NotThatItMatters
Actually, removing the error was simple.  Let me show how it arose:
[fortran]CHARACTER (LEN = 8) FUNCTION WHATEVER(IW)
! Reference to function was as follows:
A = WHATEVER(I)(1:5)
! The substring yielded the error.  Without it, it compiles fine.[/fortran]
You can't substring a function call. But in this context WHATEVER is the result value, which is a scalar, so the (I) is incorrect and made it look like a functiion call. If you want it to be a function call, you have to declare the function RECURSIVE and use the RESULT clause to give the result a different name. But you still can't substring a function result.
NotThatItMatters
Getting back to the problem at hand, I would like to launch a QuickWin SDI which has at its core a few menus and a client area which, if right-clicked, will launch a modeless dialog box.  The dialog box will have a drop-down list of choices and the customary OK and Cancel buttons.  I would like the dialog to disappear if (1) the user presses cancel, (2) the user presses the closing X (just like cancel), (3) the user presses OK which then grabs the user's choice from the drop-down list, and (4) the original QuickWin app quits.  Most of the first three would seem to follow with an appropriately formed [fortran]IRESULT = REGISTERMOUSEEVENT(IUNIT, MOUSE$RBUTTONDOWN, MouseLaunch)[/fortran].  The MouseLaunch routine would initialize the dialog and its contents.  The question then is where the message pump goes.  Is it part of MouseLaunch?  Should I be worried about the underlying QuickWin app quitting with the modeless dialog active?
