29376 Discussions
Qx compiler option and AMD processors
ggveldkamp2
I am deciding which compiler optimization options to use for a release version of our software. I am thinking about using "/O2 /QxK" or "/O2 /QxK /QaxW", this will make the minimum required cpu a Pentium III. Will the generated code also run on AMD processors with SSE (e.g. Athlon XP and better)?
Guido Veldkamp
Yes, the code will run on AMD processors, but with SSE and not SSE2 instructions. If you're going to use /Qax you may as well use /QaxN (along with ./QxK to get better performance on Intel Pentium 4 and later processors. When using the auto-CPU-dispatch (/Qax) options, non-Intel processors take the generic path (which you can set with /Qx).
ggveldkamp2
Thanks Steve. Using the auto-CPU-dispatch options increases the size of the programs significantly. We have many programs that are run very often for a relative short time, so program loading time is also important. Using "/QxK /QaxW" increases the size about 15% compared to "/QxK". I will have to try to see what's best for us. I will also try "/QxK /QaxN".
If the programs run for short times, it does not make sense to me to spend effort optimizing them. Just use /QxK and let it be.
