29278 Discussions
RC.exe not found after update to 10.1.021 edition
truelies
I uninstalled the previous editon and visual studio 2005 premier edition, then reinstalled the update. But when I run the project, it display "RC.exe not found". How to fix this?
You will need to have the WindowsSdkDir system environment variable set to the path of the SDK. For example:
C:Program FilesMicrosoft SDKsWindowsv6.0A
It could be that the VirtualPC environment is not making that available to you.
onkelhotte
New Contributor II
Somehow VS2008 did not install Windows SDK 6.0A.
Installing Windows SDK 6.1 manually solved the problem.
Markus
