29487 Discussions
RC.exe not found in VS2022 when updating oneapi
PGC
Upgraded oneapi to 2024.2 and started getting "RC.exe not found" in VS2022 when compiling a simple fortran program. Had to add C:\Program Files (x86)\Windows Kits\10\bin\10.0.22621.0\x64 to the path for Executables and Libraries.
I had to do this because the Windows Kits are installed in C:\Program Files (x86) while the variable (UniversalCRTSdkDir) points to C:\Program Files.
How is the variable UniversalCRTSdkDir normally set?
Is there a more elegant way to fix this problem?
Devorah_H_Intel
Did you try to reinstall or repair VS?
PGC
Yes. I uninstalled both VS and oneAPI and then installed following this procedure:
https://www.intel.com/content/www/us/en/developer/articles/guide/installing-microsoft-visual-studio-2019-for-use-with-intel-compilers.html
Do you know what sets the variable UniversalCRTSdkDir? Can it be modified during the installation or afterwords?
