RSA Numbers
JohnNichols
Honored Contributor I
I am a bit lost.
The RSA standard defines a block - I assume it can hold numbers as shown on
https://en.wikipedia.org/wiki/ASN.1
A picture of the format is shown below:
I am trying to work out what is the largest integer available in this format string?
I think I am looking at a 14 digit number? But I am not sure?
Anyone ever worked with this format?
Neels
New Contributor II
JohnNichols
Ignorance, thank you - I will change the code.
jimdempseyatthecove
John,
Consider the following
! set = float(prime)/100.0	! effectively shift right two decimal places
!                               ! *** 1.0/100. does not produce an exact binary fraction
! setL = floor(set)		! keep the integer part
! set = (set-setL) * 100	! produce what were the least significant two digits of prime
! replace the above with
set = mod(prime, 100)
And then consider removing the silliness of using floating point numbers.
Note, line 2 can (will at times) produce an inexact result and thus resulting in line 5 producing the incorrect value.
Jim Dempsey
JohnNichols
Thanks for the idea, I should have thought of it, but that is the beauty of peer review, it keeps you modest, maybe.
I fixed the code although it is running at the moment to do 10 million primes.
do while(flag ==0)
        read(file1,*, err = 200, end = 200)numb,ind
        cnt = cnt + 1
11      format(i2,1x,i1)
        if(ind == 0) then
            prime = numb
            flag = 1
            ind = 1
            if( set >= 0 .and. set < 100) then
                nums(set) = nums(set) + 1
            end if
        end if
            write(file3,10)numb,ind
10          format(i0,1x,i0)
    end do
My daughter wanted to go shopping in Houston today with her friend.  We are passing a building with a big number sign in red, 3033, she said I like the sign, I said it is not prime and I only like prime numbers,  she said three factors, 3, 9 and 1011, I was surprised and said nine, not likely.  High school maths teaches a lot these days.  "But she was correct, 9 and 337.
There is a significant speed difference between debug ifort and release ifx.
jimdempseyatthecove
Should numb (aka prime) always be .ge. 0 then mod(prime, 100) will always be .ge. 0, then the if test will always be true. IOW lines 10&12 are unneeded.
Jim Dempsey
