Read direct access file in block
Le_Callet__Morgan_M
If I know the record length (recl) and number of record(n) i want to read in a file is safe to:
open the file with a record length of recl*n
read the file in block
in other work can I always assume that the data will be sequential and not record delimiter will make this operation unsafe.
Was the file created with RECORDTYPE='FIXED'? If so, then yes you should be able to do this. Keep in mind that, by default, RECL is in units of 4-bytes. You might also want to look at the Fortran standard stream I/O feature that provides a POS= keyword to specify byte position in the file.
