29376 Discussions
Can't run 32 bit executables on Windows XP
Bob_W_1
On a Windows 7 machine I use ifort to create a simple 32 bit hello world program.
It runs fine on Windows 7.  The GNU file program gives this description:
hello.exe: PE32 executable for MS Windows (console) Intel 80386 32-bit
But when I try to run that same hello.exe progrram on a 32 bit Windows XP machine the OS complains that it's not a valid 32 bit executable.
So what do I have to do to get executable that will run on a 32 bit Windows XP machine?
Bob_W_1
For my hello world program that worked, I put SUBSYSTEM:CONSOLE,"5.01" in the link line and it worked.  I just made that with a make file.
But, for the main project, which is in Visual Studio 2012, I have a problem.  In the Properties dialog and the Linker All Options panel, the SubSystem field does not have SUBSYSTEM:CONSOLE,"5.01" as an option.  So I set it to Not Set and in Additional Options I put
/SUBSYSTEM:CONSOLE,"5.01"
When I try to build the linker complains:
LINK : fatal error LNK1181: cannot open input file ',5.01'
All other attempts at quoting, such as
"/SUBSYSTEM:CONSOLE,5.01"
"/SUBSYSTEM:CONSOLE,"5.01""
fail with the same message.  Visual Studio's linker has a parser designed to thwart all attempts to get this option sent to it.
So what do you people using Visual Studio do to get that option passed to the linker?
It works for me. Are you building 32-bit or 64-bit? 64-bit needs 5.02. Please attach a ZIP of the buildlog.htm showing the error - do not put the option in quotes. Please include in the ZIP your .vfproj file.
