Reading file of length zero
Diehl__Martin
I have a general reading routine that crashes for empty files (ASCII).
The following minimal example shows this behavior (compile; touch empty.txt; ./out) when compiled with ifort version 19.0.2.187. Is that the expected behavior, i.e. would I need to check for fileLength/=0 or is ifort suppost to figure this out.
program test
 character(len=:), allocatable :: a
 a = IO_read('empty.txt')
 print*, len(a)
 print*, '#'//a//'#'
contains
function IO_read(fileName) result(fileContent)
  character(len=*),  intent(in) :: fileName
  character(len=:), allocatable :: fileContent
  integer ::  &
    fileLength, &
    fileUnit, &
    myStat
  inquire(file = fileName, size=fileLength)
  open(newunit=fileUnit, file=fileName, access='stream',&
       status='old', position='rewind', action='read',iostat=myStat)
  if(myStat /= 0) stop 1
  allocate(character(len=fileLength)::fileContent)
  read(fileUnit) fileContent
  close(fileUnit)
end function IO_read
end program test
Steve_Lionel
Here's my analysis of the situation...
The READ is attempting to read zero bytes from an empty file connected for unformatted stream access. The standard says that an end-of-file condition occurs when "an attempt is made to read beyond the end of a stream file." Since the READ is not trying to read beyond the end of the file, the file position should remain unchanged and the READ should succeed.
Therefore, I believe this is an error on the part of ifort and should be reported to Intel using the Online Service Center.
Steve_Lionel
That's interesting, and another bug. Let me do some tests on that.
John_Campbell
New Contributor II
Why not simply respond to " inquire(file = fileName, size=fileLength)" for empty (size=0) or non-existent (size=-1), without opening the file.
Perhaps use  if ( fileLength <= 0) then ; allocate(character(len=0)::fileContent) ; else ; ...
Isn't fileLength = -1 already a problem ?
Diehl__Martin
The first solution leaves fileContent unallocated which requires further checks in other parts of the code (the MWE given here is not the full code).
A non-existing file is certainly a problem, but I sometimes have optional files and simply check whether they exist (with inquire)
In general, I prefer to write code without special cases.
Unfortunately, the use of modern Fortran reveals often compiler glitches (not just in Intel products) that require to use a non-optimal solution. Hence, when in doubt I try to clarify whether my code is invalid or whether the compiler does not respect the standard.
Steve_Lionel
I can't reproduce the iostat comparison issue you mentioned in post 21. The iostat properly comes back as -1 and comparing /= 0 works.
Diehl__Martin
Dear Steve,
many thanks for your investigations. Actually, I think my explanation was a little bit misleading.
  • If I read a file of length N, N>0, into a string of length N, the iostat return value is 0. Hence, I assume an error for iostat /= 0 (error: iostat > 0, read beyond EOF: iostat = -1).
  • If I read a file of length 0 into a sting of length 0, the iostat return value is -1. This seems to be a contradiction to your statement from the standard which states that -1 is returned if "an attempt is made to read beyond the end of a stream file." According to my understanding, reading 0 bytes from a 0 bytes file should also result in iostat = 0 because EOL was not reached (file length matches length of read). Due to this unexpected behavior, I need to change my code to accept an iostat of -1, even though this signals that I tried to read more information than present in the file
Finally, just for the sake of completeness (I understand that you have confirmed that already): If the iostat argument for the read statement is missing I get an segmentation fault if reading a 0 length file. This behavior is cured if iostat is present as an actual argument
andrew_4619
It would be better to use the variable with the IOSTAT_END parameter of the intrinsic module ISO_FORTRAN_ENV, or the IS_IOSTAT_END function.
Diehl__Martin
many thanks, I did not know about this. Much easier to read
Steve_Lionel
Right - that's a bug. You should be getting iostat=0 for reading zero bytes as you are not attempting to read past the end of file.
jimdempseyatthecove
What is supposed to happen when you issue this 0-byte read, as the next read following a >0 byte read that returned EOF (-1)?
IOW the internal state is "read beyond end of file". This may present a different behavior should the file be opened for shared use or for exclusive use.
Martin, had your test program (legitimately) encountered an EOF return... then issued the 0-byte read?
Jim Dempsey
Steve_Lionel
If the READ does not attempt to transfer data, it should not get an EOF condition, no matter where it is in a file connected for stream access. It is different for non-stream access.
Diehl__Martin
No, the file is just opened (as in the example given in my initial post)
Steve_Lionel
Intel informs me that this bug was fixed in the latest compiler release (compiler 2021.5.0, oneAPI HPC Toolkit 2022.1.) I had to argue a bit with the developers on this one, as they initially claimed the behavior was appropriate... I verified that the correct behavior is now seen.
