29635 Discussions
Reallocation on assignment for derived type array with deferred-length components
jwmwalrus
New Contributor II
Hi.
The following code aids in illustrating the problem.
implicit none
type :: sentence
    character(:), allocatable :: lower, upper
end type
type :: list
    type(sentence), allocatable :: list(:)
end type
integer :: i, n = 7
type(list) :: a
character(*), parameter :: LOWER = 'abcdefghijklmnopqrstuvwxyz'
character(*), parameter :: UPPER = 'ABCDEFGHIJKLMNOPQRSTUVWXYZ'
a%list = [sentence ::]
do i = 0, n
    if (MOD(i, 2) == 0) then
        a%list = [a%list, sentence(LOWER(:13+i), UPPER(:13-i))]
    else
        a%list = [a%list, sentence(LOWER(i+1:), UPPER(:i+1))]
    endif
enddo
do i = 1, SIZE(a%list)
    print *, i, ', lower=',a%list(i)%lower, ', upper=', a%list(i)%upper
enddo
end
From the code, it's clear that the a%list%lower component shouldn't have any uppercase characters, but I get the following with the ifort compiler:
$ ifort -g -O0 test.f90 && ./a.out
           1 , lower=abcdefghijklm, upper=ABCDEFGHIJKLM
           2 , lower=cdefghijklmnopqrstuvwxyzA, upper=AB
           3 , lower=abcdefghijklmno, upper=ABCDEFGHIJK
           4 , lower=ghijklmnopqrstuvwxyzABC, upper=ABCD
           5 , lower=abcdefghijklmnopq, upper=ABCDEFGHI
           6 , lower=klmnopqrstuvwxyzABCDE, upper=ABCDEF
           7 , lower=abcdefghijklmnopqrs, upper=ABCDEFG
           8 , lower=opqrstuvwxyzABCDEFG, upper=ABCDEFGH
Enabling the default optimizatiions mitigates the problem:
$ ifort test.f90 && ./a.out
           2 , lower=cdefghijklmnopqrstuvwxyz, upper=AB
           4 , lower=ghijklmnopqrstuvwxyz, upper=ABCD
           6 , lower=klmnopqrstuvwxyz, upper=ABCDEF
           8 , lower=opqrstuvwxyzA, upper=ABCDEFGH
Using the ifx compiler with no default optimizations seems to match expected behavior, except for the last entry:
$ ifx -g -O0 test.f90 && ./a.out
           8 , lower=opqrstuvwxy, upper=ABCDEFGH
And the something similar happens for ifx with the default optimizations:
$ ifx test.f90 && ./a.out
These are the compiler versions:
$ ifort -V && ifx -V
Intel(R) Fortran Intel(R) 64 Compiler Classic for applications running on Intel(R) 64, Version 2021.9.0 Build 20230302_000000
Copyright (C) 1985-2023 Intel Corporation.  All rights reserved.
Intel(R) Fortran Compiler for applications running on Intel(R) 64, Version 2023.1.0 Build 20230320
Barbara_P_Intel
Please try the latest ifx and ifort versions that were released last week. Looks to me like it's working now.
andrew_4619
I tried your code on Windows with default optimisation and no optimisation and got some different spurious variants. I suspect the array constructor is at fault as there seem to have been a number of recent bugs on this.
ifort test_dt_alloc.f90 /Od
Microsoft (R) Incremental Linker Version 14.30.30709.0
Copyright (C) Microsoft Corporation.  All rights reserved.
-out:test_dt_alloc.exe
-subsystem:console
test_dt_alloc.obj
test_dt_alloc
-subsystem:console
test_dt_alloc.obj
test_dt_alloc
           2 , lower=cdefghijklmnopqrstuvwxyz , upper=AB
           4 , lower=ghijklmnopqrstuvwxyz   , upper=ABCD
           6 , lower=klmnopqrstuvwxyz     , upper=ABCDEF
           8 , lower=opqrstuvwxyz      A, upper=ABCDEFGH
optimisation
andrew_4619
consider this program, which also gives interesting results!
program test_dt_alloc2
implicit none
type :: sentence
end type
integer :: i, n = 7
type(sentence) :: b
do i = 0, n
        b = sentence(LOWER(:13+i), UPPER(:13-i))
    else
        b = sentence(LOWER(i+1:), UPPER(:i+1))
    endif
    print *, i, ', b%lower ',b%lower, ', b%upper= ', b%upper
enddo
end
ifort test_dt_alloc2.f90
-out:test_dt_alloc2.exe
-subsystem:console
test_dt_alloc2.obj
test_dt_alloc2
           0 , b%lower abcdefghijklm, b%upper= ABCDEFGHIJKLM
           1 , b%lower cdefghijklmnopqrstuvwxyz , b%upper= AB
           2 , b%lower abcdefghijklmno, b%upper= ABCDEFGHIJK
           3 , b%lower ghijklmnopqrstuvwxyz   , b%upper= ABCD
           4 , b%lower abcdefghijklmnopq, b%upper= ABCDEFGHI
           5 , b%lower klmnopqrstuvwxyz     , b%upper= ABCDEF
           6 , b%lower abcdefghijklmnopqrs, b%upper= ABCDEFG
           7 , b%lower opqrstuvwxyz      A, b%upper= ABCDEFGH
andrew_4619
This one is well behaved. So the default constructor for sentence seem to be the problem....
program test_dt_alloc3
implicit none
integer :: i, n = 7
do i = 0, n
        print *, i, ', b%lower ',LOWER(:13+i), ', b%upper= ', UPPER(:13-i)
    else
        print *, i, ', b%lower ',LOWER(i+1:), ', b%upper= ', UPPER(:i+1)
    endif
enddo
end
Barbara_P_Intel
@jwmwalrus, Thanks for reporting this. I see the same thing with pre-production compilers
@andrew_4619, having more reproducers is great! Thank you.
I'll get a bug filed today.
Barbara_P_Intel
I filed CMPLRLLVM-49308 for you both. I will let you know when it's fixed.
jwmwalrus
New Contributor II
Hi.
It's funny how, by trying to simplify the test case as much as possible, I stumbled upon a different thing.
In the original code, the issue is with reallocation on assignment when the derived type has a deferred-length character component (and the workaround is to use MOVE_ALLOC).
The following code (which could be shortened further, I admit) illustrates the problem:
module tables
    implicit none
    private
    save
    type, public :: table_entry
        character(:), allocatable :: key
        character(:), allocatable :: val
    end type
    interface table_entry
        module procedure table_entry_new
    end interface
        type(table_entry), allocatable :: storage(:)
    contains
        procedure, private :: add_entry1
        generic :: add => add_entry1
    end type
contains
    function table_entry_new(i, k, v) result(new)
        type(table_entry) :: new
        integer, intent(in) :: i
        character(*), intent(in) :: k, v
        new%key = k
        new%val = v
    end function
    subroutine add_entry1(this, kv)
        class(table), intent(inout) :: this
        type(table_entry), intent(in) :: kv
        integer :: i
        print'(/a)','value to add:'
        print*,'key=',kv%key,', val=',kv%val
        print '(/a)','storage, before adding:'
        do i = 1, SIZE(this%storage)
            print *,i,'key=',this%storage(i)%key,', val=',this%storage(i)%val
        enddo
        this%storage = [this%storage, kv]
        print'(/a)','storage, after adding:'
        enddo
    end subroutine
end module tables
use tables
implicit none
integer :: i, n = 7
type(table) :: h
type(table_entry) :: kv
h%storage = [table_entry :: ]
do i = 0, n
        kv = table_entry(i, LOWER(:13+i), UPPER(:13-i))
    else
        kv = table_entry(i, LOWER(i+1:), UPPER(:i+1))
    endif
    call h%add(kv)
enddo
end
Please notice that I'm using a custom constructor.
Here's the output:
value to add:
 key=abcdefghijklm, val=ABCDEFGHIJKLM
           1 key=abcdefghijklm, val=ABCDEFGHIJKLM
value to add:
 key=bcdefghijklmnopqrstuvwxyz, val=AB
           1 key=abcdefghijklm, val=��I
           2 key=bcdefghijklmnopqrstuvwxyz, val=AB
value to add:
 key=abcdefghijklmno, val=ABCDEFGHIJK
           1 key=abcdefghijklm, val=0 �I
           3 key=abcdefghijklmno, val=ABCDEFGHIJK
value to add:
 key=defghijklmnopqrstuvwxyz, val=ABCD
           1 key=abcdefghijklm, val=abcdefghijklm
           2 key=bcdefghijklmnopqrstuvwxyz, val=��
           4 key=defghijklmnopqrstuvwxyz, val=ABCD
value to add:
 key=abcdefghijklmnopq, val=ABCDEFGHI
           2 key=bcdefghijklmnopqrstuvwxyz, val=ab
           3 key=��I, val=ABCDEFGHIJK
           4 key=bcdefghijklmnopqrstuvwx, val=ABCD
           5 key=abcdefghijklmnopq, val=ABCDEFGHI
value to add:
 key=fghijklmnopqrstuvwxyz, val=ABCDEF
           5 key=bcdefghijklmnopqr, val=ABCDEFGHI
           6 key=fghijklmnopqrstuvwxyz, val=ABCDEF
value to add:
 key=abcdefghijklmnopqrs, val=ABCDEFG
           6 key=bcdefghijklmnopqrstuv, val=ABCDEF
           7 key=abcdefghijklmnopqrs, val=ABCDEFG
value to add:
 key=hijklmnopqrstuvwxyz, val=ABCDEFGH
           7 key=bcdefghijklmnopqrst, val=ABCDEFG
           8 key=hijklmnopqrstuvwxyz, val=ABCDEFGH
In the original code, the table, when saved to a file, contains some caret notation symbols, so I guess this test is much closer.
And this is the output using gfortran:
$ gfortran test.f90 && ./a.out
value to add:
value to add:
value to add:
value to add:
value to add:
value to add:
value to add:
value to add:
jwmwalrus
New Contributor II
Hi.
module tables
    implicit none
    private
    save
    end type
    end interface
    contains
    end type
contains
        new%key = k
        new%val = v
    end function
        integer :: i
        enddo
        enddo
    end subroutine
end module tables
use tables
implicit none
integer :: i, n = 7
type(table) :: h
do i = 0, n
    else
    endif
    call h%add(kv)
enddo
end
Here's the output:
value to add:
value to add:
value to add:
value to add:
value to add:
value to add:
value to add:
value to add:
In the original code, the table is saved to a file and contains some caret notation symbols, so I guess this test is much closer.
jwmwalrus
New Contributor II
Btw, it seems that editing a post in this forum, makes it disappear completely.
jwmwalrus
New Contributor II
(Reposted, since it got deleted.)
Hi.
module tables
    implicit none
    private
    save
    end type
    end interface
    contains
    end type
contains
        new%key = k
        new%val = v
    end function
        integer :: i
        enddo
        enddo
    end subroutine
end module tables
use tables
implicit none
integer :: i, n = 7
type(table) :: h
do i = 0, n
    else
    endif
    call h%add(kv)
enddo
end
Here's the output:
value to add:
value to add:
value to add:
value to add:
value to add:
value to add:
value to add:
value to add:
Barbara_P_Intel
Thanks for another reproducer! I added it to the bug report.
Ron_Green
@jwmwalrus we have a fix in the works for this one.  Look for it in 2024.0
Barbara_P_Intel
The reproducers are printing the correct results for both ifx and ifort with the compilers that were released earlier this week.
Please check out the new compiler versions!
jwmwalrus
New Contributor II
Hi.
Thanks for the follow-up.
I'm still getting similar behavior with the latest version of ifort/ifx:
This is the code (same as the one posted above):
module tables
    implicit none
    private
    save
    end type
    end interface
    contains
    end type
contains
        new%key = k
        new%val = v
    end function
        integer :: i
        enddo
        enddo
    end subroutine
end module tables
use tables
implicit none
integer :: i, n = 7
type(table) :: h
do i = 0, n
    else
    endif
    call h%add(kv)
enddo
end
And this is the output I get:
(ins)$ ifx -V test.f90 && ./a.out
Intel(R) Fortran Compiler for applications running on Intel(R) 64, Version 2024.0.0 Build 20231017
 Intel(R) Fortran 24.0-1238.2
GNU ld (GNU Binutils for Debian) 2.41
value to add:
value to add:
           1 key=abcdefghijklm, val= �I
value to add:
           1 key=abcdefghijklm, val=0��I
value to add:
           2 key=bcdefghijklmnopqrstuvwxyz, val= �
value to add:
           3 key= �I, val=ABCDEFGHIJK
value to add:
value to add:
value to add:
Barbara_P_Intel
Well, heck! I tried it before I posted the news and I thought printed correctly. But it doesn't.
I'll let the compiler person know.
Barbara_P_Intel
@jwmwalrus, the two cases you posted actually two different bugs according to the compiler engineer. Both will be fixed in 2024.1.0 due to be available in a few months.
Adelson_BR
I have a similar problem that seems to point to a different origin of this bug.
Suppose that in the original code by @jwmwalrus one redefines the type sentence:
type :: sentence
end type
to a new one like that:
type :: sentence
    real, allocatable :: A(:)
  ! real, pointer :: A(:)
end type
Note the option to declare the component A as a pointer.
In my code, the component A is corrupted after reallocation of a%list if A is allocatable. But A is NOT corrupted after reallocation of a%list if A is a pointer that is allocated before it.
Thus, I believe this bug is not triggered by reallocation only.
Hope this reply helps.
I can post a snippet code if necessary.
Barbara_P_Intel
@Adelson_BR, a complete reproducer would be useful! The compiler team likes to confirm fixes against multiple examples.
Adelson_BR
Hi, Barbara_P_Intel,
Sorry for the delay.
The folowing code reproduces the bug and also shows that using pointers prevents the bug.
The idea is to work with a structure (C) that contains another struture (C(#)%B) that in turn contains matrices A (C(#)%B(#)%A). Reallocations of C and C(#)%B are made in a subroutine but one could reproduce the bug in a DO loop as @jwmwalrus  did. Like the problem reported by @jwmwalrus, the content of matrix A is corrupted when C(#)%B is reallocated.
The code is in the attached file teste_realoca_tipos.f90.
I've tried ifx and ifort 2023. I also tried gfortran. Gfortran does not even compile for versions up to 12 but Gfortran works fine for versions 13+.
Adelson_BR
@Barbara_P_Intel ,
I did not test this with ifort 2024 yet.
Thanks a lot.
Barbara_P_Intel
@Adelson_BR, what output do you expect from your code?
I also tried commenting out the ALLOCATABLE and using POINTER. I got a runtime seg fault.
