Intel accepts CLASS & PARAMETER
Harald1
New Contributor II
The Intel compiler accepts the following code silently:
program p
  type t
     integer :: i = 1
  end type t
  type(t),  parameter :: a = t() ! Legal
  class(t), parameter :: b = t() ! Likely not
  class(*), parameter :: c = t() ! Likely not
  class(*), parameter :: d = 1   ! Likely not
end
I've been informed that F2018 disallows the marked lines:
C708 An entity declared with the CLASS keyword shall be a dummy argument or have the ALLOCATABLE or POINTER attribute.
Is this due to a missing check in the compiler, or am I missing something?
Harald
Barbara_P_Intel
Both ifx and ifort are printing error messages now! Please check out 2024.1 that was released last week.
Steve_Lionel
PARAMETER is right out.
Barbara_P_Intel
Thanks for bringing this up. I filed a bug report for both ifort and ifx, CMPLRLLVM-37714.
This will be a two-for-1 fix, a 2-fer, since they share the Fortran Front End.
Barbara_P_Intel
Harald1
New Contributor II
It is fixed indeed.  Great, thanks!
