29432 Discussions
PDT: KIND and LEN type parameters are mutually exclusive
Harald1
New Contributor II
The following invalid code is erroneously accepted by ifort 2021.4.0:
  type :: bad_pdt (k,l)
     integer, kind, len      :: k = 1
     integer, len, kind      :: l = 1
     character(kind=k,len=l) :: c
  end type bad_pdt
end
 The Fortran 2018 standard (and similarly 2003+) state:
F2018: 7.5.3.1  Type parameter definition statement
R732  type-param-def-stmt is
      integer-type-spec, type-param-attr-spec :: type-param-decl-list
R734  type-param-attr-spec  is KIND or LEN
(3) The type-param-attr-spec explicitly specifies whether a type parameter is a kind parameter or a length parameter.
Thus the KIND and LEN attributes are mutually exclusive.
The correct solution would be to reject the code sample.
Harald
Barbara_P_Intel
I filed a bug report on this issue for you, CMPLRIL0-34368. I'll let you know when a fix is available.
jimdempseyatthecove
FWIW your type declaration is (may be) non-conformant. From:
   A type declaration has the general form:
   type-spec[ [, att] ... ::] v[/c-list/][, v[/c-list/]] ...
Thus your:
Is ?ambiguous??
The presence of the "integer, kind, len" part of the statement are of the old/legacy format declaring kind and len as integers. However, you statement contains "::", which now state that the ", kind, len" portion are attributes. So, which are they? Attributes or variables of integer type? If attribute, there is no attribute named "kind" nor "len".
Jim Dempsey
Harald1
New Contributor II
Jim,
I was talking about F2003 parameterized derived types.  I wouldn't call that "old/legacy" yet.  Maybe you are thinking of some old/legacy DEC/Intel extension?
The compiler should provide a means to reject non-standard-conforming code.  The above sample violates F2018:R734.  "ifort -stand" remains quiet.
Harald
Steve_Lionel
I agree that the compiler should complain. This is not an extension, just a lack of error checking.
Barbara_P_Intel
Barbara_P_Intel
With the 2024.1 release both ifx and ifort are printing error messages.
These compilers were made available last week. Please try them!
Harald1
New Contributor II
It is indeed diagnosed properly now.  Thanks!
