29283 Discussions
Recommended hardware configuration for CVF 6.6
emreka82
Years ago my thesis supervisor has bought this program (CVF 6.6b) and now he wants me to continue their project as my doctoral project. I am familiar with programming but I haven't used Compaq Visual Fortran before...Anyway, I get used to work with it an since it does not compile in Windows 7 I am working on Windows XP in Virtual PC but it is very slow to run and compile. Now I want to buy a new computer and that is what I am asking...What must be the most important part of the configuration... RAM ? processor ? etc... Can you give me the best configuration that I have to get ? By the way, I am also using TecPlot for post processing, so these two programs must work simultaneously for 3D graphics. Thanks for your attention.
Emre Kara
Mechanical Engineer, MSc
Ademiloye_A_
netphilou31 wrote:
I did not noticed the problem before because of the following reason. Since CVF version 5 (I think that it was Digital Visual Fortran at that time), I was using the WinTabs addin with VisualStudio (addin that add tabs feature to the IDE, very helpful). However I noticed that with version 6 it crashed the application. I have been able to look at the addin code thanks to the original developer and found that it was expected to work also with MSDEV.exe. Thus, I fixed the problem by simply making a copy of "DFDEV.exe" and renaming it "MSDEV.exe" (in the same directory as he original file) and since I worked with MSDEV instead of DFDEV !. I went a little bit further by changing all the references to DEFEV.exe in the registry to MSDEV.exe but I don't think that it is necessary to go so far.I understand that it is a little bit complicated but it works !
Worked for me... Thanks
